C5/C6 wheel fitment
C5/C6 wheel fitment
Thanks in advance. I know this question has been asked before, but I'm going to ask again as I've seen differing answers. Will all factory C5 wheels fit my stock 1989? Will and C6 wheels fit my stock C4. I happen to live in an area where there is a seller with multiple sets of C5 and C6 rims with and without tires. I don't have an interest in changing anything on my car to accommodate new wheels and tires, so I'm hoping to see if C5 wheels/tires and/or C6 wheels and tires will fit with no modification.
Update: I ended up purchasing a very nice set of painted 5 spoke rims 8.5"x17" front and 9.5"x18" rears from a circa 2002 C5? Thanks for all the replies. I think I'll do a dry fit to see if the 3/4" spacer makes a huge difference. Do the folks who have used the 3/4" hub centric spacer recommend all four corners are only the rears? Thanks again!
The C5 will fit without spacers/adapters but the rears for the base C5 wheels will be slightly inboard. (about 9mm (about 0.35") compared to the C4 wheels.)
The sizes and offsets are listed below.
88-96 base
16"x 8.5"- 50mm
17"x 8.5"- 56mm
17"x 9.5"- 56mm
ZR1 rear
17"x 11"- 36mm
Grand Sport rear
17"x 11"- 50mm
C5 base
17"x 8.5"- 56mm
18"x 9.5"- 65mm
C5 Z06
17"x 9.5"- 54mm
18"x 10.5"- 58mm
I put C5 wheels on mine a couple times. See pictures below. Without any spacers.
Note that the rear C5 tires are taller than the fronts, so it will change the "rake" of the car. I did not like that change and if you have stock C5 run flats they are very stiff too.
C5 wagon wheels (the thinspokes (polished or painted) have the same sizes and offsets.)
C5 Z06 wheels (replicas with the same sizes and offsets as stock)
88-96 base
16"x 8.5"- 50mm
17"x 8.5"- 56mm
17"x 9.5"- 56mm
ZR1 rear
17"x 11"- 36mm
Grand Sport rear
17"x 11"- 50mm
C5 base
17"x 8.5"- 56mm
18"x 9.5"- 65mm
C5 Z06
17"x 9.5"- 54mm
18"x 10.5"- 58mm
I have not used C6 wheels on mine, but the sizes and offsets are listed below.
C6 base
18"x 8.5"- 56mm
19"x 10"- 79mm
C6 Z06
18"x 9.5"- 40mm
19"x 12"- 59mm
So my best guess on C6 wheel fitment is that the front base C6 wheels would fit fine. The rear base C6 would be too far inboard and would need spacers/adapters. The C6 Z06/GS would not be a good fit. The fronts are too far outboard and the rears are simply too big to fit so there could be problems rubbing on both the inside and outside.
Good luck
C6 Z06
18"x 9.5"- 40mm
19"x 12"- 59mm
So my best guess on C6 wheel fitment is...The C6 Z06/GS would not be a good fit. The fronts are too far outboard and the rears are simply too big to fit so there could be problems rubbing on both the inside and outside.
C6 Z06
18"x 9.5"- 40mm
19"x 12"- 59mm
