C4 Corvette Interior Restoration Replacement Parts Mega-Thread-Sale!
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Southern Car Parts is quickly becoming a leading supplier of reproduction C4 Corvette interior parts. Below are just a sample of what we offer. You can find parts here:
Interior parts here: https://www.southerncarparts.com/c4-...ior-parts.html
C4 Corvette Armrests :https://www.southerncarparts.com/cat.../?q=c4+armrest
C4 Corvette Shift Boots: https://www.southerncarparts.com/cat...=c4+shift+boot
C4 Corvette Switches: https://www.southerncarparts.com/cat...t/?q=c4+switch
C4 Corvette Replacement Seat Foam: https://www.southerncarparts.com/cat...q=c4+seat+foam
C4 Corvette Interior Door Panels: https://www.southerncarparts.com/cat...c4+door+panels
C4 Corvette Armrest Pads: https://www.southerncarparts.com/c4-...-cushions.html
C4 Corvette Seat Covers: https://www.southerncarparts.com/cat...c4+seat+covers
C4 Corvette Sun Visors: https://www.southerncarparts.com/c4-...lh-and-rh.html
C4 Corvette Roof Panels: https://www.southerncarparts.com/c4-...headliner.html
C4 Corvette Console Door Lid: https://www.southerncarparts.com/198...-door-lid.html
C4 Corvette Floor Mats: https://www.southerncarparts.com/cat...=c4+floor+mats
C4 Corvette Pedals: https://www.southerncarparts.com/198...nsmission.html
C4 Corvette Bezels: https://www.southerncarparts.com/cat...lt/?q=c4+bezel
C4 Corvette Speaker Emblems: https://www.southerncarparts.com/198...r-emblems.html
C4 Corvette Steering Kit: https://www.southerncarparts.com/cor...ng-p-9138.html
C4 Corvette Shift *****: https://www.southerncarparts.com/cat...=c4+shift+****
C4 Corvette Door Sills Pads: https://www.southerncarparts.com/c4-...pads-pair.html
C4 Corvette Window Regulators: https://www.southerncarparts.com/198...or-p-9021.html
Oahu750S (05-02-2019)
I was looking at the seat foam and was hoping you could clear something up.
Here is the description. Can you please clear up the discrepancy in the years.
1991-1993 C4 Corvette Sport Seat Foam 8 Piece Set
When you are restoring the interior of your C4 Corvette you should replace the seat foam when you install new seat covers. Over time the foam will break down from use. If you but new seat covers on old used foam then your new seat covers may not fit correctly. Our reproduction C4 Corvette seat foam is correctly formed and includes pre-installed wire supports where applicable. These C4 Corvette seat foam kits are made by Corvette America in Reedsville Pennsylvania.Application: 1989, 1990 Corvette
Supporting Vendor
Thank you!
Hard to believe you couldn't find a page on your own site but here it is
https://www.southerncarparts.com/199...piece-set.html
Here's a screen shot as well.
Supporting Vendor
This fits 1991-1993, the fitment in the description is wrong and will get updated on Monday.
I have a 1984 needing complete rear carpets replaced, all faded, best choice for replacement “Corvette America “ catalogue.?
Drivers seat seam needs restiching, please advise. Thank you very much
Supporting Vendor
C4 1994-1996 CORVETTE SEAT BACK RELEASE BEZEL BLACK $12.94
This Seat Back Release Bezel Black will certainly help you restore your C4 1994-1996 Corvette and help you bring home those trophies at the summer circuit of car shows. Southern Car Parts is here to help you with your restoration from start to finish. All of our reproduction C4 1994-1996 parts and accessories are built to meet and most times exceed the original equipment standards from General Motors.APPLICATION: C4 1994, 1995, 1996 CORVETTE
https://www.southerncarparts.com/c4-...zel-black.htmlC4 1984-1989 CORVETTE INTERIOR LIGHT DELAY TIMER BOARD $40.00
Have you noticed the interior lights in your C4 1984-1989 Corvette are staying on instead of dimming out on a delay like they once did? It is most likely the Interior Light Delay Timer Board. This is the part that turns the lights on and off after you open and close the door.Why buy the whole unit which costs double the price when you can just replace the circuit board with this new reproduction unit that costs much less. This Is The Circuit Board Only For Use With Original GM Module # 10098435.
APPLICATION: C4 1984, 1985, 1986, 1987, 1988, 1989 CORVETTE
https://www.southerncarparts.com/cor...rd-p-9028.html
C4 1990-1991 CORVETTE DASH VENT INNER VENT GRILLE LH $42.95
Does your A/C blow on your face when its 100 outside or blow into your interior where you aren't? We have the solution to your broken or missing A/C vent issues. This C4 1990-1991 Corvette Dash Vent Inner Vent Grille LH is an exact replacement for your broken or damaged vent and is easily installed in place of the old piece.APPLICATION: C4 1990, 1991 CORVETTE
https://www.southerncarparts.com/cor...le-p-9047.html
You guys have any plans for door panels for the later cars? My 92 needs both sides replaced and the 269.99 price looks pretty good to me if they're decent quality.
