I'm getting ready to replace Front Control Arm Bushings......
…....and am asking for any tips or tricks that others may have used to remove the rubber bushings from the upper control arms.
I could probably figure it out..... because I learn from my mistakes...… but this is one of things I can't afford to make a mistake on.
I couldn't even find a YouTube video, or I was not searching using the right words. Either way, just looking for some advice.
I have a 12 ton press, and I am sure it will come in handy.
Thanks, Jared
Thanks, Jared
Corvette Central DIY may have information. GM did not released c4 control arm bushings as a service part. Arms were intended to be serviced by replacement. A little heat will be required to get nuts off shaft. Once nuts are off things should go well.
Alrighty.... I am off to a pretty good start. Instructions would certainly help but looking at the bushings and the hardware helps a lot in figuring out how it comes apart and goes back together.
I screwed up the install of one of the bushings..... I inserted the sleeve out of sequence and the bushing would not bottom out in the arm, it was just mushrooming the bushing where I was pressing. Popped it back apart and rerouted my strategy.
One of the things that also helped in the end was a 3 jaw puller. When inserting the last bushing.... on the right in the pictures, it would still not bottom out completely because of the preinstalled retainer on the shaft. Without the sleeve inserted, I installed the outside cupped washer and the nut, tightened the nut to the point where there was pressure on the bushing, and then pulled the arm onto the bushing using a 3 jaw puller. Worked like a charm and now I am going to tackle the lower control arm.
I'm doing this one side at a time so that I will have a reference to look at in case I get my reinstallation out of order.
Jared
Jared
I'm wishing I would have taken a picture of the way I used the 3 jaw puller, I could do an entire step by step for someone else based on what I learned.
The front end is done!! The new rack and pinion got installed with urethane bushings, sway bar got urethane, and of course the upper and lower control arms. The kit even included urethane boots for the tie rods.... so I figured what the hell.
I did a rudimentary "toe" alignment with some twine and made several test drives to get steering wheel position straight and to correct any pulling that the car was doing. It still has a very slight drift to the right (which it did before I started) but is better than it was. Steering wheel is straight, and the car tracks pretty straight when I dynamite the brakes. I'm going to consider this close enough to still be able to drive it until I get the bushings in the rear suspension swapped out. At that point I will schedule the car for a 4 wheel alignment.
I have quite a few pictures, and will include them all. The 12 ton press is a Harbor Fright unit that I found on CL for $60 a year or so ago. I didn't even need it at that time but figured it would come in handy one day.
It really is too bad that my new Bilsteins are on backorder... 12-14 weeks is the estimate. I took the car up a winding climbing backroad earlier at twice the posted limits for the corners and it almost felt like it was glued to the road...…. It was fun!!
Jared
Jared
The following 3 users liked this post by lotsofspareparts:
Jared
Jared
it.
