1996 front spoiler
1996 front spoiler
Getting ready to remove/replace the 3-piece front spoiler on my GS. Can one guy do this job or not? The C5’s are a cinch to replace but the C4’s are different. Any good tips out there if only one guy attempts this task?
Replaced the air dam on my 92 a while back. Not too bad, took about half hour. Trick was getting the holes lined up for the bolts. An imported Chinese knock off did'nt fit perfectly but I finally got it on. It's already scratched up again lol!
It will be easier if you put the car up on ramps. I just took off my fiberglass one (cracked it when I misjudged pulling in at an angle) and put the factory one back on. It is pretty quick, especially on ramps.
Spoiler
Okay thanks to all.... I was curious if only one guy is doing it? How did you get the nuts on the bolts from up above? Don’t you have to push the bolts up through the bottom, then install the nuts from down inside the hood? Of course the center piece you can do from the bottom side since the screws are right there in front of you. But the the 2 sides I’m thinking aren’t like that, instead, the bolts go up through and inside the front hood area.....
Also, this would be a great opportunity to add a screen to the intake area to keep out leaves and other debris from collecting in the condenser-radiator area.... one of the main issues affecting our cooling systems.
IIRC, all the fasteners for the C4 front spoiler can be accessed without opening the hood.
Some people get fancy and use this type of perforated plate material: perforated sheet
Do some searches and you will see what people have done to cover or screen this air intake area.
This is a great modification, as long as airflow is not significantly impeded. These cars really need something like this instead of just an open gaping hole to swallow everything.
Here are some pictures of my setup, it works great:
Marty-Vancouver-WA (06-11-2019)
Went out to the garage to check it out what you said here.... my GS Must be different than yours...lol. No way one can’t avoid opening the hood to access the nut on the bolts that are on the sides of the spoilers. I’d love to read exactly how you did that..... just askin’....
No problem.... another poster pm’d me said the nuts are stationary on the L/R spoilers. Supposedly the nuts remain fixed so until I check that out I’ll with hold my opinions...👍
thanks
thanks
^ If that is true about the fixed nuts, then it seems all 3 sections can be removed/installed without opening the hood. Interested to hear your experience when done with your work.
I haven't messed with anything but the center section and that was just to install the wire mesh... also several times I have used a lighter to melt/adjust the center blade to direct more air upward My pieces are factory originals, I think.
