Convertible top
Old 05-13-2019, 11:09 PM
Ajax87
Junior Member
Default Convertible top
Hello All,
I recently purchased a 1996 Corvette convertible. The weatherstripping in a few areas need repair/replacement. The top appears to be ok, but worn. I checked pricing for the weatherstripping and a whole set runs around $360. I happen to see that a new convertible top cost is not much more in cost. Would you guys recommend simply buying a new convertible top?
Ajax87 is offline
Old 05-13-2019, 11:22 PM
65Z01
CF Senior Member
65Z01's Avatar
Cruise-In II Veteran
I don't think a new top comes with new WS, though I might be mistaken, and am sure installing a new top is a tad more effort than replacing the WS.
65Z01 is offline
Ajax87 (05-14-2019)
Old 05-13-2019, 11:38 PM
RalfKramden
CF Member
Weatherstripping is NOT included when you buy the replacement canvas top. Also if you plan on replacing the weatherstripping, you may as well do the top since you have to remove the weatherstripping in order to replace it anyway. I'm in the middle of that project myself (among others).
RalfKramden is offline
Ajax87 (05-14-2019)
Old 05-14-2019, 06:19 PM
Ajax87
Junior Member
How difficult is the installation? I am pretty handy but never installed a canvas top. I was also considering buy a hardtop because of the wind noise.
Ajax87 is offline
Old 05-14-2019, 11:59 PM
RalfKramden
CF Member
I'm doing it for the first time myself. So far, so good. just time consuming, especially removing all the weatherstripping and the glue. One of the tips that I found recommends using Xylene, soaking paper towels then laying them in the channels. That's a home run b/c after about 15 minutes you can basically wipe the glue away with a dry paper towel. I only have a few more spots to remove the glue from then it'll be on to placing the top. Hoping it warms up some to make the top more pliable. This page https://tech.corvettecentral.com/201...-installation/ is the one that's helping me the most. Good luck if you tackle it. Didn't want to spend the $1k plus it's been said to cost for the job. You'll have to replace the weatherstripping at the same time b/c it gets destroyed trying to remove it. Good luck if you tackle it!
Quick Reply: Convertible top
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
