1989 speaker amps
1989 speaker amps
The Right Front speaker in my 89 ragtop gives nothing but static. I have removed the amp and have it in the shop for assessment. If it is beyond repair I am contemplating swapping out one of the amps from the rear speakers. The 2 rear speakers seem to be at a lower volume than the front am am wondering if they are compatible as as replacement for front speakers before I go to the trouble of removing one.
Cruise-In II Veteran
If needed I would rather recommend buying a front amp from say e-bay.
In my '89 a **** on the face plate unit is used to adjust the balance between front/rear relative volume.
NavAir is correct...the amps also include equalization for their location in the cabin. They can be rebuilt in most cases. Dr. Dons is one source. https://www.doctordons.com/
There are sources for Cadillac versions and other car models that used them but I understand the issue is the same on the equalization. And I think they all will fail at some point if you buy used.
One of the guys I work with is an electronics geek. He repaired all 4 amps in my 89 by changing a couple of resistors. I had the back ones done first since they were the easiest to get out of the car. I think my total cost for all 4 was around $40 which included his time and the resistors. The hardest part was getting the ones out of the doors and then back in.
