looking for trustworthy engine service ne Ohio
hey everyone
I was getting the vette checked out and I asked my mechanic to give a checkup on leaks and such that may be visible and such - still working on getting a baseline to get the car healthy. although nothing was urgent he recommended the valve seals and said it would be a good idea to have the motor pulled and all the seals done. so I am looking for anyone that might know of a shop that might do this and how much should I expect to spend? I am in the Youngstown Ohio area by Akron/Canton sort of I am going to try to find some local vette people as well - but I thought if anyone had this done or knew of any reliable shops - that would be very helpful
thanks
Sean
thanks
Sean
hey everyone
thanks
Sean
thanks
Sean
I had some spots last fall - nothing too much - changed the oil pressure sender seemed to stop - but there are still areas on the motor that appear a little wet - nothing crazy though - again just trying to shore up as much as possible - wanted to be sure there is nothing else lurking - but if I can do a little at a time and save a little that would be ok as well - I believe regardless heads will need done - seals
thanks
thanks
thanks
thanks
Valve seals, probably. Heads, why?
sb66 (05-23-2019)
engine r&r for seals and such is going to be labor intensive, that is where you will get most of your cost
I am straight across 224/76 from you. If you get on 224, go west until it starts running with I-76 (on the west side of Akron) then continue to the 13 mile mark, which just happens to be St Rt 21, that is where I live. I know of some shops around here, one of them just sold his Chevelle to the owner of the shop on Restoration Garage (on the Motor Trend Channel). If that guy is going to buy a car from the guy out here, that should say something.
There are also some other reputable shops in the Akron area.
I am also getting a wet spot on the garage floor. Nothing real bad, yet. Could be the pan needs tightened up, could be the rear seal.
sb66 (05-23-2019)
thanks everyone - I had smoke at the start of the spring after sitting - which I thought the same if the seals were an issue I would see more - but the plugs were so bad last year to the point of almost no power. they were covered. I know there is nothing urgent to what I am seeing but if I can head a few things off at the pass I think that would be better right? I am not sure how much I can do myself (my knowledge and skill set are at times questionable) and how involved some of these would be - I guess that is part of it - plus the piece of mind with a knowledgeable person doing the work - I am not necessarily afraid of it just cautious - after all it is still a corvette . right?
thanks I did hear that about these very true - was not sure how much they would find when in there - not sure how involved the sea job on this car would be - again being a vette I did not want to mess it up
If valve seals were bad, you'd see smoke at every startup. I think you are worried about nothing. Having someone pull the engine to replace seals would cost you a fortune. Probably unnecessary also. Leave it alone is what I'd tell you
sb66 (05-25-2019)
probably (and hopefully) right - sometimes get sidetracked and too obsessed - I will continue to watch - I try to keep it maintained regularly so I am sure if something gets worse hopefully we'll notice it more. There were other seals I had hoped to replace this year (door, window etc.).
I will keep an eye on it - thanks
Sean
Sean
just curious though if I did have to do the valve seals - how difficult is that?
Finalist 2020 C4 of the Year - Unmodified
I started becoming an amateur mechanic after I bought my '87. I did a lot of fixing this and that over the years, but not much on cars. Two years later or so, with the help of the C4 CorvetteForum, Youtube, FSM and a little brain, I replaced the valve seals, pulled the heads and other things.
The seals can be changed without pulling the engine. It does take a bit of work to move this or that to get the valve covers off. Also need this and that tool to pull springs, etc.
Odd though, I wouldn't expect spot leaks if the valve seals are worn, oil would go out the exhaust.
sb66 (05-25-2019)
hey everyone
thanks
Sean
thanks
Sean
sb66 (05-25-2019)
use this phrase for a google search
most common lt1 oil leaks
and do some reading, there are lots of threads on the web about LTx oil leaks
such as
https://www.corvetteforum.com/forums...on-96-lt1.html
of course there is always Fat Guy's Garage over there by Youngstown :-) :-) :-)
such as
sb66 (05-25-2019)
thanks - the suspicion with the valve seals came then the plugs were removed and in such a state that the car would barely accelerate - covered with quite a bit of oil - I am going to watch to see how soon before that becomes an issue again.
I am not sure if it is worth pulling and replacing all of the seals - I was thinking I would try to get the car up to snuff so to speak - and see if the leak I had was a real issue. it of course would not leak for the mechanic - but he thought a good way to resolve this could be to have that done - but after hearing back from several of you I am questioning the need for that - maybe just take on each as it becomes necessary - (?)
thanks
thanks
thanks drcook
I have the l98 - I am sure the leak concerns sound the same - the front and rear seal was one of my biggest concerns and I feel that would be more obvious - I looked again today and noticed a small amount of seepage on top by one of the intake bolts - making a little puddle on top - but not enough to make a spot on the floor. (still not sure what that is though)
you mentioned fat guys garage near Youngstown?
Have you checked the compression?
sb66 (05-25-2019)
