93 vert. Headlights open / close but motor spins longer
Curious if anyone knows what might be going on.
the headlight motors keep spinning for a couple seconds even after the headlight has either fully opened or fully closed
used to not do this
any ideas?
used to not do this
any ideas?
I did a rebuild a few months ago for the same issue. Ended up just replacing the pellets, which had disintegrated. I had planned on replacing the gears as well, but they were in basically perfect condition and got reused.
"I would suggest using the plastic instead of the brass. If there is a problem you would rather strip the plastic gear and save the motor which runs in the $300 plus range than have the brass gear hold together and ruin the motor." This from a C4 owner which most agree with
