1987 ABS Computer Control / power reply
Old 06-07-2019, 07:42 PM
bobby64
Junior Member
Default 1987 ABS Computer Control / power reply
My ABS light stay on. My mechanic advised that it was the ABS computer Control / power reply. However, this part has allegedly been discontinued. I check with several corvette part distributors, Vendors including EBay with no luck. Part number Bosch / 0 332-512-006. Possible GM part number 14084083. Can anyone help me locate this relay or have any suggestions how to solve this problem. Thanks
bobby64 is offline
Old 06-07-2019, 08:24 PM
hcbph
CF Senior Member
hcbph's Avatar
Forget GM if you're looking for ABS relays etc for a C4. Go against, Porsche, VW, MB and a few others. Here's some info I tracked down when looking for replacement relays for my 86 the other year. Check Ebay using the Bosch number off the relay, you'll do better that way.
ABS Relays
Update: Went back and started looking up some of the models
Module Relay 0332002171: BMW E30 ABS Anti Lock Brake Pump Relay 318is 318ic 325i 325is 325ic 325ix
Mercedes W126 W123 W107 W124 W201 relay 0332002171
0 332 002 171 PORSCHE / AUDI / VW OEM ABS PUMP RELAY
Solenoid Relay 0332205003; BMW E30 Mercedes Corvette ABS Pump Breaking System Relay Bosch 0332205003
NEW Bosch Relay (ABS) 0332205003 BMW 34511154919
ABS SYSTEM RELAYS VOLVO 740 - 760 - 780 - 940 - 960 / BOSCH 0332205003
Possible alternative for 0332512006: 0332512007. That one has a skirt that would have to be trimmed, but first look appears it may be the same relay in a different housing.
I was just going against the Bosch numbers on them I wrote down from mine:
Module Relay: 0332512006 - Looks like there's another possible but would have to do a little trimming on it.
Pump Motor Relay: 0332002171
Solenoid Relay: 0332205003
hcbph is offline
Old 06-08-2019, 08:16 AM
bobby64
Junior Member
Thanks, This is my first time on the corvette forum. If you come up with anyone who may have please let me know. I have a 1987 Coupe with 21000 miles. I really would like to drive it this summer but hesitate due to the ABS light being on.
bobby64 is offline
Old 06-08-2019, 10:11 PM
hcbph
CF Senior Member
hcbph's Avatar
With the abs light on, if it's like mine it means you're driving a car without abs. You still have your normal braking, just not abs all else being equal.
hcbph is offline
Old 06-09-2019, 12:06 AM
Benny42
CF Senior Member
Benny42's Avatar
With the part numbers that hcbph provided you can order relays from your local auto parts store. I ordered thru O'reilly (ABS power relay for my '86) and
it was shipped from Germany. $42.99 relay, $2.80 service fee & $7.74 shipping and It took a week to arrive. Full function restored and no more ABS light.
Benny42 is offline
Old 06-10-2019, 07:44 AM
bobby64
Junior Member
Thanks Benny
Do you what auto store order this part / reply for you. I'm been searching ever where with no luck.
bobby64 is offline
Old 06-10-2019, 07:47 AM
bobby64
Junior Member
Sorry, didn't read you post closely, I see you got it at O'Reilly
bobby64 is offline
Old 06-10-2019, 11:38 PM
Benny42
CF Senior Member
Benny42's Avatar
Go in with a part number and have them cross reference it. If it comes back it their computer as an ABS relay ( for a BMW or MB) then have them order it and be prepared to wait a week or so.
Benny42 is offline
Old 06-12-2019, 07:00 PM
hcbph
CF Senior Member
hcbph's Avatar
Here's a little trick that 'may' help prove it's a relay issue. Open the well up with the pump in it and using a plastic faced hammer or a plastic screwdriver handle rap the relays a couple of times. Now try starting the car and see if the light is out or not on startup. Mine went out for a couple of startup/drives then came back on, confirming to me it was a relay issue. Apparently in my case, the relays were sticking probably due to burn contact (my assumption),
I found my relays on Ebay, and well worth the cost and much less than any listed for Corvettes. I replaced both the main relays in mine, one was for a Porsche and the other was for a MB. Being they had the same Bosch number on them, it was plug and play and worked perfectly.
hcbph is offline
Benny42 (06-12-2019)
Quick Reply: 1987 ABS Computer Control / power reply
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
