Opening front hood-weight
Old 06-09-2019, 07:11 PM
stabac
CF Senior Member
stabac's Avatar
Default Opening front hood-weight
1985- the hatch has struts to assist in opening. Are there any springs, counter weights, etc to help with the hood or is that just dead weight? I'm not as young as i used to be
stabac is offline
Old 06-09-2019, 07:15 PM
Cruisinfanatic
. 1985 Original Owner .
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ....... .......Clearwater, FL
2 small struts in front of hood.
Replace them
Amazon Amazon
Cruisinfanatic is offline
Old 06-09-2019, 09:42 PM
stabac
CF Senior Member
stabac's Avatar
Thanks Cruisinfanatic I ordered 2 just now. That will make life much easier for an old fart like me
stabac is offline
Old 06-10-2019, 12:51 AM
JETS C3-C4
CF Senior Member
When you replace them you may have to unbolt the hood support arm to get enough travel to
take the pressure off to remove and install the new ones. If you need to remove the hood support brace what you can do is take some rope and wrap it around both hood springs and then tie off to a rafter or what ever you can above to allow the extra movement and support the hood.
One person can change them but two people is a little easier. Besides the second person can hold your beer while you are working.
Good luck and let us know how you like the struts you got from Amazon.
JETS C3-C4 is offline
Old 06-10-2019, 08:38 AM
RockyL32
CF Senior Member
RockyL32's Avatar
Location: If your not the lead dog the view never changes Boise, Id
I swapped mine out. It made no difference in weight till about half up.
RockyL32 is offline
Old 06-10-2019, 08:43 AM
hcbph
CF Senior Member
hcbph's Avatar
Almost ditto. No difference all the way up and down vs the originals. I did end up putting back on the originals because of it. Not a difficult task if you're organized.
hcbph is offline
Old 06-10-2019, 09:06 AM
3D-Aircrew
CF Senior Member
3D-Aircrew's Avatar
I changed out my gas springs and there was an immediate difference in the way the hood came down. It takes no effort to hold the hood up upright but you still have to hold on to it when closing where I usually drop the hood from 10" to close it.
3D-Aircrew is offline
Old 06-10-2019, 09:48 AM
Randy M
CF Senior Member
Randy M's Avatar
I highly recommend swapping out your locking support to the newer style gas spring. I did mine years ago on my 85 and would not go back to the original support. I takes no effort at all to lift my hood. I still have the small ones up front. The retrofit requires moving the support to the left side to work. If I remember correctly it was a kit and included the end brackets. You may need to get the later end brackets from an 88-96 now to make it all work. Definitely worth the trouble.
https://www.zip-corvette.com/85-96-h...elescopic.html
https://www.zip-corvette.com/85-87-h...elescopic.html
Randy M is offline
Quick Reply: Opening front hood-weight
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
