Buying C4 maybe...give me a good listen please have a fee questions
OOOPS! I mean have FEW questions.....
And thanks so far for the info! All stuff sounds doable not a major deterrent to make a purchase.
It's a 1994 conv C4. That's the LT1 and the R700 4 speed auto trans...correct?
How much is the headlight fix? They are not flipping into position smoothly.
How much is it to replace the clear protective tape on the deck lid for the conv top. Its unsightly and yellowed
And has a trans leak....can that be the trans pan? Or the output shaft seal? Any other things going on with these automatics and leaks?
And the windshield might need replacing. Expensive? How much..
Is there an AC button...or is it just with the temp control.....the vents move slowly but do move. How much to fix?
Thanks for the info...I can give more details as I decide if I'm gonna pull the trigger.
I know it's an old car and it won't be perfect. And that I will have to fix this stuff. I can work on it myself with and friend who is a tech.
Can you folks who know these C4s chime in? Thanks in advance for the info...
And I'm excited! So my typing is brief!
Thanks! Big Al
Thanks! Big Al
Received 6,943 Likes
2015 C2 of Year Finalist
the engine is a LT-1 (350ci-300hp) with a electronic 700R4
Headlight repair is a afternoon job. many many write ups and articles/ videos on how to repair
the clear tape is purely a aftermarket item. if you can still buy it; it can't be that much to replace it
the trans leak could be many of things. it could be a 1 dollar "O" ring on the speed sensor, pan gasket, or output seal. don't know until you look at it
windshield call your local windshield shop and ask. your insurance might replace it for your deductible
the AC button could be many of things.
1993C4LT1 (07-21-2019)
Thanks! Big Al
Thanks! Big Al
If the nylon bushings are all that's gone in the headlight motors, you're looking at somewhere around 10 bucks a side. If the gear is also gone (stripped, broke, etc), you're looking at around 20 bucks a piece. I bought two sets off ebay (bushings and gears) for around 30 bucks, shipped. Only the right side of mine is "winking", but I'm just going to replace both and be done with it. If one side is gone, the other side is probably not far behind.
All this is assuming you can do your own work repairing the motor drives.....the price goes up pretty quickly if you have to pay someone else to do it.
Ok thank you. Things dont sound too bad.
The AC does work.....but the buttons are slow...not sticky. But the flaps aka arir directional items are slow to respond
And...I cant find an actual AC button.
Am I missing something?
Thanks!
Big Al
And I checked thru the RPO codes....just a base model conv vette with Bose stereo
All checks out!
Thanks!
Big Al
All checks out!
Thanks!
Big Al
All checks out!
Thanks!
Big Al
All checks out!
Ok look into the vac check valve. So that is not too bad.
Thank you!
I found this out....
Re: How to turn on the AC
Push the button that says "AUTO" then set the temp (use the down arrow) to 65 degrees or lower. The compressor should start to cycle on and off.
So that is a weird way to turn on the air conditioner compressor...but if you say so! Lol. Sound familiar?
Thank you!
Does the car have the optional electronic selector or the base manual slide control. If you don’t have a owners manual I would suggest you buy one and read it
C4 of Year Finalist (appearance mods) 2019
The point that you are missing is that the way the system was designed you set the temp that you want to maintain and they system will maintain it "automatically". If the system "decides" that the AC compressor should come on to assist in the maintenance of the temp .... then it comes on.
TWO exceptions:
If you select the windshield defrost then the AC will come on regardless of ambient temp to blow "dry" air on the inside of the windshield.
If you sent the temp control down to it's lowest setting which I think is 60 degrees then the AC will also kick on automatically.
You are correct in there is no dedicated AC button.
TWO exceptions:
My 1993 Coupe had a problem with the buttons not functioning on the climate control. There is a video on how to repair them but I tried, successfully, to use a spray (CRC Electronic Cleaner from Autozone) It comes with a straw so you can spray behind the buttons and this, along with my air compressor blowing the cleaner even further) worked fine. Cost about $12.00. Good luck on your car. You will love it!
The clear tape is not aftermarket. It was put on at the factory to keep the convertible top from marring the paint. There might be a vendor who sells the reproduction, of not you can go to a local clear bra installer and have them duplicate it,
Owners Manual
go to: https://www.chevrolet.com and select 'Owners Manuals", then select the year, make, and model. Then you should see an active link for the owners manual.
There is a lot of older content available in the C4 section- just do a search. A lot of the newer questions were issues years ago.
Good luck with your new Corvette.
Ok. Just picked it up.
I love it! Just cant describe how ya melt into this thing and become one with the car
Everything is ok.....the car ran cooler than I remember when first seeing it on Sunday
But I do have an burning oil smell coming from an oil leak.
Where do these things leak from?
Valve cover? Some sensor or other gaskets in the engine?
But yes...I'm gonna keep it all stock...maybe some roller rockers...and drive drive drive
Gonna have a little trouble sleeping tonite....lol
Thanks! Big Al
Thanks! Big Al
The LTI is notorious for intake oil leaks. Valve covers can too. PS it already has roller rockers
Ok thank you everyone. Yes it's super fun! Who knew that the c4s were so cool and rode great and yet had performance. Almost afraid to say, almooooost like this better than my c6 I had! (Shhhhhh)
Ok, question. With this board, should I start a "project thread" or just ask individual questions under individual topics?
Example.... i want to know what ratio steering I have, I might need a new rack and pinion.
And my stereo and pass electric seat dont work. What fuses do I check? That is where I would start.
So, do a main project thread or do individual threads. Thanks! Al
