I've never replaced one of these before....if anyone knows the part number and where it can be purchased, I'd be grateful. I did the intake gasket and valve cover gaskets this weekend and this green plug is the only part I broke. Thanks in advance.
If you believe that you can release and reuse the terminals etc. yes. Now for an assembled pig-tail that you could cut/splice OR release and reuse you might have other options. I don't know what a Mouser minimum is these days. Many locals likely have a 3 terminal 'Weather-Pack' that would require no shipping - just pick up and move along.
Weather-Pack towers are frequent easy finds an any local auto parts stores, farm & fleets etc.
Missing only the latch it seems, so even though a bit unsightly just a cable tie to secure it
Appreciate the info WVZR-1. Agree re zip tie existing part as the only piece that I broke was the little clamp/clip. That's what I'll do temporarily, but I'm picky and it will bug me knowing its broken, so I went ahead and ordered a new one. I'll definitely keep Pico in mind for additional wiring parts I end up needing.
yep, familiar with them. I will typically buy only the shells as that is what is broken, or if I am making my own harness for something. Very rarely have I ever bought a pigtail.
What was the ship from Mouser if that's where you did the buy? I don't often use Mouser as a source but generally only buy the shell also. There's some very reliable sources for most of the correct 'Weather-Pack'.
