Dash wiring
Ive been very deep into many early car dashes and i’ve completely gutted a 90. There are others here who have done this several times but not documented.
In the shop manual did u post a yesr?) there are “component views” that DO SHOW how chunks of the harness fit and route within the dash. very desirable for you at this point. its a manual trans, what year?
I've never done a C4 Instrument Panel or wiring harness R&R. But I've done a zillion other GMs from the 60's to the 90's. In every case, the harness and ducting is installed in the IP prior to the IP being installed in the car. When I do phases of a project such as "IP, ducting, and wiring" I evaluate how it was done at the factory, then emulate how they did it. It usually comes out pretty good.
If a flat-dash C4 is similar to a 1st Gen S10 (I've done at least 15 IP R&R in these) the IP had everything preinstalled except the external trim pieces. The heater box was on the firewall, the pedal bracket was probably on the firewall. I don't know if the windshield was installed yet or not, but shouldn't make a big difference. After the IP bolts are in, then the C100 is pushed into the firewall, the ends of the harness routed into the doors, etc.
Asses and evaluate how the factory had to do it 25 times an hour, and do it the way they did it.
