Spark Plug Wires
Old Apr 23, 2003 | 01:23 AM
khoerner's Avatar
khoerner
Navigator
Default Spark Plug Wire Replacement
I am a pretty fair shade tree mechanic, but when I looked at the engine to install a set of spark plug wires on a 95 LT1 it looks pretty daunting. Is there any trick to installing the drivers side wires on the distributor without removing the water pump? Maybe from underneath? The passenger side boots look to be pretty easily accessible, but I can't even get my hand down the driver's side... :confused:
[Modified by khoerner, 6:27 AM 4/23/2003]
Old Apr 23, 2003 | 11:12 AM
BaseballDude's Avatar
BaseballDude
Default Re: Spark Plug Wire Replacement (khoerner)
There are many here that have done it, but I'm 6'3" and my hands are too big for certain jobs (like this one). I took a 15 minute look at the job (with the car on jack stands) and decided to have a mechanic do it. This was when I first bought the car almost 4 years ago. Given another chance and having much more familiarity with the car now, I would probably tackle it myself, though I'm sure I would be doing a lot of :cuss :cuss :cuss along the way. :lol:
Old Apr 23, 2003 | 11:20 AM
khoerner's Avatar
khoerner
Navigator
Default Re: Spark Plug Wire Replacement (BaseballDude)
Ok, I know it can be done with effort, but it's sure not going to be the 1/2 hour job it used to be! Just hoping there was some "trick". :banghead:
Old Apr 23, 2003 | 12:11 PM
95AquaC4's Avatar
95AquaC4
Remove driver side dust sheild from inner fender well. Wires are tight, but can be pulled out from underneath. I removed my belt, and put a wrench on the tensioner pulley and pulled it all the way out of my way. I was able to access the opti from where the tensioner pulley would have been with the belt on. Set aside some time, and have patience. Good luck.
Old Apr 23, 2003 | 12:22 PM
khoerner's Avatar
khoerner
Navigator
Default Re: Spark Plug Wire Replacement (95AquaC4)
Hey thanks! That looks like it will work pretty well. Actually, it looks like removing the belt, then both the tensioner and idler pulleys (the two small ones) would open up a nice access area even from the top. Thanks for the idea!
:thumbs:
Old Apr 23, 2003 | 01:11 PM
khoerner's Avatar
khoerner
Navigator
Default Re: Spark Plug Wire Replacement (lani's 93)
Well, I'm can't personally speak for their quality yet, but I purchased a set of SplitFire Dual-Mag wires along with the SplitFire spark plugs. I have researched them and found both pros and cons on the web, but most of the cons had to do with the price. However, SplitFire is offering rebates of $2.00 per plug, and $15.00 per wire set. http://www.splitfire.com/rebate/rebatesf.htm
They also have a 30 money back guarantee, and a Lifetime warranty.
I paid $82.00 for the plugs and the wires (found a really cheap place http://www.247autoparts.com/store/index.html, prompt shipment), and with the rebate I'll only have paid $51.00 for the whole shebang. My thinking was that if they sucked I wouldn't be out that much, but now I see I'll be out an afternoon of labor whenever I want to change them. :eek:
The wires look to be very good quality though; extremely low resistance (good), spiral wound, kevlar cores, thick, etc. The one thing I've read that makes sense on the plugs themselves it that they should be gapped a bit higher than factory recommended so the spark is forced to be "stronger", i.e. since there is more available area with the SplitFires the spark can theoretically be weaker when it crosses the gap. In that line of thinking, increasing the gap corrects this. I plan on going to .054 from the recommended .050.
I'll post with the results when I've tested them out.
[Modified by khoerner, 10:21 PM 4/25/2003]
Old Apr 24, 2003 | 03:50 PM
radwebster's Avatar
radwebster
i got these plugs and wires for my C3, never installed them yet. let me know how they work out. :cheers:
Old Apr 24, 2003 | 05:02 PM
Lone Ranger's Avatar
Lone Ranger
Those would be the wires for the #6 and #8 cylinders. It is important to make sure these two wires each have a plastic wire protector sheathed over them as they pas by the dipstick tube. Look what the dipstick tube carrier is bolted to-- the exhaust manifold. It gets hot. I even took the precaution of physically putting a slight bend on the dipstick tube to increase the distance between it and the plug wires, even though I have the high temp wire protectors on my #6 and #8 plug wires.
I'm curious what plug wires are you installing? Will they be the GM stock ones?
I had mine changed about 14 months ago at the dealer because the two wires going to the right rear plugs that come into close proximity with the oil dipstick seem to short out against the tube. Now its doing it again. To alleviate some of the missing, I put some electrical tape around them there and it cleared up about 85% of the miss.
So I'm wondering if this is a common issue or unique to mine? Plus is there a higher quality wire over the GM set that would work better?
I don't look forward to doing this either.
thanks, Lani
[Modified by Lone Ranger, 4:02 PM 4/24/2003]
Old Apr 24, 2003 | 05:35 PM
khoerner's Avatar
khoerner
Navigator
Default Re: Spark Plug Wire Replacement (Lone Ranger)
Had to stop for a few minutes, I'm about 6 hours in, but the end is in sight. I'll make a full report when I'm done, including every trick I learned. I think it would only take 4 hours or less knowing what I know now. :cry
Old Apr 24, 2003 | 05:37 PM
BaseballDude
....I'm about 6 hours in, but the end is in sight. I'll make a full report when I'm done, including every trick I learned. I think it would only take 4 hours or less knowing what I know now. :cry
:eek: :eek: :eek: :eek: :eek: It would have been faster to remove the water pump.... :lol:
Old Apr 24, 2003 | 06:39 PM
Lone Ranger
Its a smooth black plastic that is spiral wound and you thread it onto the wire like a spiral, sort of. But the corrugated type you mentioned would probably also work-- that kind is what is on my ignition coil wire, but the plug wires have the spiral kind.
I think you can get it at a dealer parts dept. Be sure to specify high temp resistance spark plug wire protectors.
The plastic wire protector sheath your speaking about, is that the black plastic tubing with flexible ridges in it?
If so is that something that can be bought from GM or somewhere in linear foot lengths?
Like I was saying earlier putting electrical tape on those two cleared up about 85% of the missing that was going on. So I feel I'm headed in the right direction.
Thanks, Lani
Old Apr 24, 2003 | 06:41 PM
Lone Ranger
Also Lani, I would replace the two wires with new ones if they have been perforated by a burn-through against the manifold or the dipstick tube. Even if you insulate them enough with tape or wire protectors to stop arcing/shorting they probably still aren't delivering voltage as efficiently as they did before the damage. On the passenger side like that they shouldn't be too hard to swap out.
Thanks, Lani
Old Apr 24, 2003 | 08:10 PM
Lone Ranger
When you say 'spiral' that is to say it has spiral slit in the smooth plastic? Lani
:yesnod:
Old Apr 25, 2003 | 05:20 PM
khoerner's Avatar
khoerner
Navigator
I just used the old ones. The wires I used are rated 1000 F, so burn thru should not be a problem. See above. Let me know if you have any questions on install.
BTW, there is no reason to remove the water pump. In fact, it wouldn't even help much.
[Modified by khoerner, 10:23 PM 4/25/2003]
Old Apr 25, 2003 | 05:57 PM
Lone Ranger
Ok, I've been calling different parts houses and searching the net, I have not been able to find high temp spark plug wire protectors. If you know where I can get them or the raw material I would be most appreciative.
Lani
I thought dealer parts dept. had them, because when dealer installed new wires on my car during GMPP warranty claim they put on some of the spiral slit wire sleeves. I searched the net using 'spark plug wire guard', 'spark plug wire sleeve', and 'spark plug wire protector' with no luck. Couldn't find them on Summit racing site either. Weird. Would think they would be sold where plug wires are sold. I'll keep checking...
Old Apr 25, 2003 | 06:38 PM
GDP's Avatar
GDP
Let us know when you get through!
Old Apr 29, 2003 | 11:34 PM
Lone Ranger
I know, I've been doing the same thing as we post. Summit was about the closest with some kind of sleeve or boot sleeve about 8" long for $10.
I called Chevy parts today and they said no its not a GM part. Go figure. I haven't given up yet.
LS
Try specifying spark plug wire heat shields, part # 12132232, this may be the correct designation for the parts guy at the dealership to find it. Maybe not . I found this part number on a Impala SS LT1 discussion.
To Spark Plug Wires
