Optispark.....What is it?
Old May 7, 2003 | 12:12 AM
Cal Vette's Avatar
Cal Vette
Default Optispark.....What is it?
I keep hearing that these go out. I hate to sound stupid, but what is it? How much do they cost and what happens when they go out. Where is it located? My 92 has 59k miles, how can I tell if it was replaced. :confused:
Old May 7, 2003 | 12:19 AM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Re: Optispark.....What is it? (Cal Vette)
i think the optispark replaces the distributor on the LT1/LT4 cars.
I'm not sure where it's located since I don't have a vettem but I heard people saying it's somewhere near the water pump, which people were complaining about since the optispark doesn't like water.
I might be wrong so don't take my "vetteless" word for it
Old May 7, 2003 | 12:55 AM
VetteHawk's Avatar
VetteHawk
Default Re: Optispark.....What is it? (DanielW)
:iagree:
DanielW just check my fund today $16945.00 mabey we'll reach are goal about the same time. I want a Black LT4 with Z51. YOU?
Old May 7, 2003 | 07:28 AM
Red Tornado's Avatar
Red Tornado
its a name for the cute system otherwise known as optical ignition.
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
The optispark is the distributer on the LT1/LT4 motors. In this picture you can see it behind and below the waterpump with the plug wires running to it. :steering:
Old May 7, 2003 | 09:36 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Optispark.....What is it? (Ramrod92)
It's not as bad as people make it out to be. It is very sensitive to water, but what ignition system isn't?
On my '95, GM put the improved "vented" version which last scads longer than the earlier design.
It's a very good idea that was executed too quickly and took a couple years to get it just right and then they changed it when the LS1 engine came out.
There are some who have converted their Opti's to the LS1 style ignition system, I'm going to be one of them since the opti on my '93 just crapped out.
So far I have seen an opti last over 96,000 miles with no problems including a water pump that blew, but that was on a '96.
Here are a few links to look over
http://www.charm.net/~mchaney/optisprk/optisprk.htm
http://para.noid.org/~muttvette/opti.html
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
http://bailey-eng.com/LTCC.html
Old May 7, 2003 | 09:43 AM
Lord Odin's Avatar
Lord Odin
Default Re: Optispark.....What is it? (Mr Mojo)
I think my optispark lasted about 80k miles and would have kept going if I hadn't gone through a foot of water at 30mph. :eek:
Old May 7, 2003 | 09:57 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Mine had 88,000 on it and then I broke it changing wires, don't ask.. :nonod:
To Optispark.....What is it?
