1996 Corvette BLACK paint
Quick and easy question....I don't believe that the 1996 Corvette's Black exterior is a clear coat car, but I wanted to ask for a general consensus on whether it is or not.
Reason: I am looking at purchasing Zaino Bros. car care equipment and want to make sure.
Thanks :confused:
Thanks :confused:
St. Jude Donor '04 & '05
Re: 1996 Corvette BLACK paint (fortworth396)
It should be a clear coat.
I had mine repainted and had 7 coats of clear put on it.
Anyway.
Good Luck.
tony
Anyway.
Good Luck.
tony
Re: 1996 Corvette BLACK paint (Southern Comfort)
All factory painted 96 Corvette's have clear coat.
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Re: 1996 Corvette BLACK paint (meyre1)
Thanks all for the advice. Just went to Zaino Bros. and ordered all the right stuff. Much appreciated !!
1 Post
St. Jude Donor '05
CI VI Veteran
Has your car been painted? Many times when someone paints black or white, they go to a single stage. (If the color of your car comes off on your rag when you polish it, then you do not have clearcoat)
Didn't I just post this answer to someone else? :skep:
Mark
Mark
My black 96 never looked better than after the "full" Zaino treatment.
It is a lot of work but you will like the results!
I think it is man. They should all be clear coat from the factory unless the clearcoat was removed afterwards.
