Lazy Headlight
Old Dec 9, 2003 | 11:54 AM
Jelly Roll's Avatar
Jelly Roll
Default Lazy Headlight
I've got a lazy headlight on my 88 convertible. I'm not very well versed mechanically, but I was wondering if there's hydrolic fluids involved. There looks like there's some kind of container involved with the pop-up mechanism? I've already tried WD-40 on the moving parts :rolleyes:
Old Dec 9, 2003 | 12:05 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Lazy Headlight (Jelly Roll)
no there is no fluids, you need a rebuild... Not sure if you need the new gears or just the bushing kit. I'm at work and don't remeber what years would be what and don't have time to look it up. Sorry not a lot of help.. Go to the tech tips and look for it, I know it's there somewhere.. Good luck. :seeya
Old Dec 9, 2003 | 12:34 PM
BAM92's Avatar
BAM92
Default Re: Lazy Headlight (fsr402)
Just need the bushing kit. Might as well order them for both. One starts going usually the other is not far behind. Cost less than 15 bucks for both and about an hour of your time to install them. Ecklers, Mid America and Corvette Central all carry them.
Old Dec 9, 2003 | 12:47 PM
QuikZilver's Avatar
QuikZilver
Default Re: Lazy Headlight (BAM92)
:iagree:
Bushings are shot.
Old Dec 9, 2003 | 12:54 PM
Jelly Roll's Avatar
Jelly Roll
Thanks, replacing the bushings seems to be the consensus choice. Love this site :D
Old Dec 9, 2003 | 01:02 PM
QuikZilver's Avatar
QuikZilver
You may want to look at the gear too. I replaced the driver side bushings and installed a bronze gear at the same time so I wouldn't have to worry about the plastic gear stripping. The bronze gears run $60 and include the bushings. Just another option. I don't want to rebuild them again. Still need to find the time to do the passenger side. It took me about 2 hours or so to do the driver side. Good luck! :smash:
Old Dec 9, 2003 | 01:59 PM
NightRyder's Avatar
NightRyder
Default Re: Lazy Headlight (Whitvette)
and while thats a nice idea, ive heard that its better to let the $15 plastic gear strip instead of the moter going south.
Old Dec 9, 2003 | 03:00 PM
Bob Taylor1's Avatar
Bob Taylor1
These work similar to power window gear heads. The bushings inside are the culprit most of the time and not hard to change at all.
Old Dec 10, 2003 | 08:24 AM
Shark ssn591's Avatar
Shark ssn591
Open the hood & watch the motors spin, if they spin after the light has moved you need the bushing kit.
Had the exact same symptoms, over time it will quit working, get the bushing kit. Wait for good weather & fix it.
from
2 88-96 Headlight Motor Repair Kit 444359 4.95 Kit
88-96 factory headlight motors contain a drive gear that is gel packed, and it is this packing that fails and allows the motors to free wheel. The repair kit contains 3 Delrin bushings that replace the gel and allow the motors to operate properly. Easy installation - one kit needed per motor. Instructions included.
http://www.corvettecentral.com/
[Modified by Shark ssn591, 8:25 AM 12/10/2003]
Old Dec 10, 2003 | 11:24 AM
Jelly Roll's Avatar
Jelly Roll
Default Re: Lazy Headlight (Shark ssn591)
Ordered the kit yesterday, thanks :cheers:
Old Dec 10, 2003 | 11:38 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:cool: :thumbs:
Old Dec 10, 2003 | 12:48 PM
RutsRup's Avatar
RutsRup
I would advise against the bronze gears. The stock nylon gears are designed to strip if the headlight ever has trouble opening, thus saving the headlight motor. The bronze gears will tear up the entire motor and housing, and probably damage the hood. I replaced the bushings in my car and, after fifteen years, the nylon gears are still in perfect shape, so I don't think you ever have to worry about the gears stripping or wearing out.
To Lazy Headlight
