Can anyone tell me where the EGR Temperature Switch is located on my '85 vette coupe?
I purchased a new one, thinking that if I saw what it looked like, I could find the old one. I don't have a clue. The switch screws into the engine. and has a wire plug at the end. My repair manual talks about the switch, but not about where it is at. :confused:
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: EGR Temperature Switch??? (65Z01)
What led you to replace the temp switch? Did you follow the diagnostic procedure through the GM manual?
You can test the EGR temp switch off of the car by hooking up a voltmeter between the wire lead and the metal body of the temp switch.
Now, set your meter to check for continuity, and hold a lighter under the end of the temp switch. It should show continuity within 20 seconds or so when it heats up.
code 32 doesn't necessarily (or even usually) mean the temp switch is Bad - it means it's ON. Why becomes the question - is the EGR valve itself stuck? Is it being left open by a faulty control solenoid (most likely cause in my experience - those control solenoids seem to me the weak link in the system). The Helms (GM) manual has a pretty good diagnostic procedure for sorting out this issue..... Don't condem the temp switch! It's usually the messenger, not the message... :nono:
Re: EGR Temperature Switch??? (1slyder1)
I had a bad temp switch, and there was no code 32. I actually tried disconnecting it.. and running the car, and it still didn't set even when the EGR opened.
You can diagnose the egr solenoid by grounding the ALDL diagnostic ports, and there's something else... I'll check the manual. You'll also need a hand vacuum pump to see if its' actually opening and closing allowing vacuum to the egr at correct times.
I'd rather replace the solenoid than the temp switch any day. At least the solenoid isn't buried under the plenum.
I've had this car for about 16 months, and have no idea how good (or bad) the previous owner took care of it. The way I figure it, it's an '85, and if I keep on replacing sensors, relays, etc., she'll eventually be a new car. (I have already rebuilt the tranny and replaced several relays.)
I appreciate all of y'alls help. I can always count on the corvette forum to steer me right. :thumbs:
Normal running temp is 200+deg F but I run a 160 deg T-stat & fan switch so my coolant temps normally run 155-165deg F. Only when air temps climb into the 90s does my coolant temp get into the 170deg range.
:lol: :cry That's what I used to think.
Now I'm starting to believe that those small expenses are just there to warm me up to the idea of dumping hundreds of dollars into it every month without hesitation.
Well, I replaced the solenoid switch last night. Reset the engine codes. So far, so good. No code 32. Now, all I have left, is to replace the knock sensor. I am not complaining. I'm just glad these are things that I can do myself. :D
