my dash flashing "sys"
Old Jan 24, 2005 | 05:13 PM
chilihed'95coupe's Avatar
chilihed'95coupe
Default my dash flashing "sys"
This morning when I started my car the area of my gauges where you see the fuel mileage info kept flashing "SYS" about every 30 seconds. Does anyone know what this means?
Old Jan 24, 2005 | 05:50 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
In most cases it means a weak battery, it can also come on if you've done anything with the stereo. Usually anything related to an electric problem can make the SYS come on. I would check the battery first.
Old Jan 24, 2005 | 05:56 PM
VFR750's Avatar
VFR750
I started a thread about this a month ago. Mine turned out to be a battery. Nice warning, actually. It's better than waiting for the battery to fail.
http://forums.corvetteforum.com/showthread.php?t=976260
Old Jan 24, 2005 | 09:29 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
Check fuses. all of them
Old Jan 24, 2005 | 09:35 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I'd check that first. When I bought my car a week later this happened to me. I freaked!!! I went to start my car and the battery shot craps on me... changed the battery and everything was fine from there.
Old Jan 24, 2005 | 09:42 PM
White Six Speed's Avatar
White Six Speed
Just happened to me. Replaced the battery after having it checked. Had about 1000 cranking amps when it should of had 5000 That is what I was told, Changed battery and have not had any more sys flashing
White Six Speed
Old Jan 25, 2005 | 12:10 AM
Matt O's Avatar
Matt O
Default Matt O
Had the same thing - battery was bad. Installed new battery and message was gone....Good luck!
Old Jan 25, 2005 | 01:26 AM
OrthoAggie's Avatar
OrthoAggie
mine does it because of the stereo...i need to solder in that resistor to make it go away...
Old Jan 25, 2005 | 02:31 PM
chilihed'95coupe
Thanks everyone. The day before this happened I got my car washed, and it was really hard to start pulling out of the car wash. Drove home just fine. It was the next morning that it started easily, then I got the sys light. I'll check my battery tonight. Thanks again.
Old Jan 25, 2005 | 08:55 PM
iceman_t1's Avatar
iceman_t1
Got the same thing last spring, it was the battery.
Old Jan 26, 2005 | 07:26 AM
Atok's Avatar
Atok
If you're looking for the real reason for SYS...It means a code is stored in the CCM. If you read the CCM code it will tell you exactly why it's flashing. Generally, most CCM codes are electrical related. A weak battery can set CCM codes randomly.
Old Jan 26, 2005 | 08:22 AM
runner140*'s Avatar
runner140*
Default Its your battery...
Might be time to change your battery. We can now start a new thread, which battery should I buy?
Old Jan 26, 2005 | 05:58 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
The Energizer Bunny has my vote
To my dash flashing "sys"
