Old Car, Old Man, One Gets Restored, One Doesn't
No Flash
Flash
Not too bad, even though I hate carpet it is probably best.
The problem. You can see the two tabs broken off in the upper part of the pic. Fortunately I had one piece of the broken off tabs as it was attached to the lid so I could see the proper shape of the tab and location/placement of the U-shaped speed nut. If anyone needs to do this in the future the correct thread is an m6x1. I bought a 50 pack in 304 stainless for $10, probably a two lifetime supply but it was cheaper to buy 50 than two, go figure.
I still had the filter part of the 90 base and it had close to the right shape I needed to replace the tabs.
I just needed to cut them out, heat them up and mold them into the right shape. This turned out to be harder than expected, the memory of this plastic is incredible, it took vice grips to hold them in shape, they held the heat in for several minutes so I could not hold it by hand.
Once they were close to the right shape, which you will note is conical, this is to provide the strength needed to keep them from pulling up, I began a series of epoxy and glass to get the shape finalized and for added strength.
Once the shape was right, the thickness right to hold the speed nut in the correct position I then epoxied the speed nut in place.
I had one more and insignificant concern to deal with, the inside where the two pieces overlap, it is an abrupt change in airflow, if I had been thinking far enough ahead I would have tapered these before epoxying them into place but I did not. I have a cheap burr set but they are not long enough to reach inside and shave down the edges. They need to be able to reach about 8" into the cavity and I could find none that long online. I used a long drill bit and "chewed" as much off as I could. It is not perfect but it is better. I really should have dealt with this before joining the two halves together. I think a 1/2"x18 or 21" belt sander would be the easiest tool to use to smooth the transition perfectly after the fact, but I don't have one and will probably have to revisit this transition in the future. The opening is still the original size of the 89 airbox, it is just that hard sharp angle I want to remove. It is probably completely irrelevant because the air flows from small 89 section into large 90 section and not directly into that 90 degree part but instead air flows over it, but it will create an eddy that will disrupt airflow. it also gave me the chance to ensure the epoxy that dripped out was cleaned up to keep it from breaking off in the future and going into the intake.
The problem.
After a good chewing with a drill bit. There will still be some turbulence but it won't be as bad now.
It is almost time for paint, I decided on 2K HotRod black, hoping it will be durable enough. Truck bed liner would be perfect, except for the crazy texture. I was unable to find one that didn't have crazy texture and the ones that has less texture were rubber based and that would not be durable. There is a Durabak-18 which is a smooth version but is cost prohibitive.
I managed to get the alignment pretty close to perfect, there is a slight bend in the center line but you can't see it when looking at it. The box needs to come to the passenger side about 1/8" and I am not going to worry about it, I Frankensteined this together and can't expect perfection.
I also swapped out the knock sensor with the correct one, I lost maybe a tablespoon of coolant, it went easier than I expected. I am going to up the base timing to either 10 or 12 degrees as recommended by FiTech, the current 6 degrees may be limiting power as there is a limit on what the ECU can do for timing advances. It has been about a month since the car has been started and it fired right up this morning.
After my back stops hurting it is on to the front carpet which I expect to go smoothly, I just have a lot to remove to do it.
I have been researching these headers and how to make the best use of them. My pre-cats are the only cats on the car, the center one has been hollowed out. I want to run a cat and see it is probably going to have to be a high flow replacement for the center cat or two of the little bullet cats. Hooker used to have a Y-Pipe to make this install easier but it is no longer available and is 2.5" and pinched down on the drivers side. I hope to be able to come out of the headers with a 3"x16" extension before going to a smaller pipe, if there is room, I have a feeling there is not and that is why the Hooker pipe is pinched down. The extension will probably have to have a bend in it to get it going in the right direction. I have a lot more research to do after taking some measurements and bending some wire for fitment before I can do anything. Planning is fun, more fun than the actual work.
I have learned a lot on how to do the carpet color amending so that it covers the fibers all the way around and not in just one direction. My first venture with the MAMO/SEM product I now consider a failure in some parts of the carpet from trying to make an inconsistent carpet base color uniform. The old carpet was matted down and no longer "fluffy", this is important, it has to be fluffy and a consistent color for all of the pieces if you want a consistent color for the finished product.
Below is what I did and will include the steps in case someone finds this thread in the future while searching for a carpet color correction.
Step one, vacuum the new carpet and old carpet, you really don't want dirt or loose fibers getting coated and buried in the coating.
Step two, use a stiff plastic brush to brush all of the fibers in the same direction, I used a brush designed to clean fragile A/C fins, it had firm but long flexible bristles that did not remove any of the carpet fibers. I did two pieces at a time but you could easily do all of the carpet at the same time.
Step three, once all of the fibers are in the same direction and the can of dye has been shaken enough you will apply a dust coat on the carpet, you do not want to put a heavy coat on as you will have three more coats to put on. Less is more. I waited about three minutes after the dusting and brushed the carpet with the same brush in the same direction as earlier. This helps to keep the fibers separate and prevent clumping of the fibers, the product hasn't cured yet but also was also dry enough to not be removed. I would think temp and humidity would affect how long to wait. It was dry to the touch, if it still tacky then wait until it isn't.
Step four, exactly the same as step three but this time brush all of the fibers in a different direction than you did in step three.
Step four, once it has been coated in all directions and brushed right after applying and completely dry from the steps above, give it a final brushing. The color should be what you after and it should be consistent. I let it cure for about a week but that isn't necessary, I was doing other things and wasn't ready to install it yet.
Once you have all four directions coated it should be a consistent color no matter which direction the fibers are laying. It should also still be relatively soft, not hard or brittle feeling. The new carpet pieces came out better than the existing carpet on the door panels and floor mats, this is because the fibers were easily manipulated in the new carpet and stay where brushed to old carpet would not.
A word on the MAMO/SEM product, you really have to shake it a lot the first time. I put the cans in the Sun for about an hour before using, you also have to shake the can good before every pass, it seems to settle out of suspension easily. If you don't keep shaking it, the thicker base will clog the nozzle, I learned that the hard way.
Before and after pics of the color change.
It came out better than I had hoped it would.
I also did the rear speaker box, it did not come out perfect but it is better. Since I had the box and amp all apart I ran the wires into the chases I created when I built the boxes.
The interior being put back together.
I may order another can of the "dye" and color change the cup holder. The shine, color and texture are wrong and it makes it stand out too much.
All in all it was worth it. It is sad that no one makes this carpet in the right color, it cost as much for the "dye" as it did for the carpet. My original plan was to replace all of the carpet with something else but in the end the best direction to take the car was to just fix the carpet and make it consistent in color. I am happy with how it turned out and now it looks like it belongs. I am not sure what to do next, I considered making the armrest black as it would tie the black seats into the black dash. I am still undecided on that, it will make the armrest hot in the Summer and I don't know if I want to put my arm on a hot armrest purely for aesthetics.
I had said long ago I wasn't interested in doing any car shows, however, there is one next month that will be four miles away from me. I may attend that one for grins. I have zero expectation of ever winning anything with this car as I live in an area with a lot of old geezers and their custom rides that I cannot compete with, in any class, and I am OK with that. I am also hesitant to do car shows any more because of the manners and etiquette of the general population these days. The last thing I want is to be keeping people from crawling all over the car. I have friends who have had to deal with that lately, I have worked too hard on this to have someone use it as a jungle gym. lol
What I brought home.
A decent change in appearance and function.
Time to make the tubing go away.
The removal was really easy, a simple Dremel cutoff wheel to cut them and a flap wheel on my grinder to smooth out the factory weld. I had a lot more pics but a corrupted SD card made them all vanish.
The little tubes protruded into the header tube, I ground those down as well.
I also cut off the 3-bolt flanges and picked up some Mishimoto 3" V-Band clamps to weld on. I ground down the welds that held the original clamps on instead of cutting the tubes in front of the welds. I am glad I did it this way, the V-Bands would not have fit the 3" collector tube and would have needed to be ground down a little as the tube is slightly larger than the V-Band.
My little Harbor Freight Titanium 125 handled this easier than I expected. I got this little welder for field repair on fencing and anywhere I did not have electricity as both of my generators can handle the electrical needs of this thing. Using Lincoln wire it splatters as you would expect, to combat that as much as possible, I wrapped foil around the pipe only exposing where the weld was needed. It kept most of the splatter off of the pipe and worked beautifully. The 40 grit flap wheel cleaned up the booger welds well enough.
I am not a welder, I am a grinder. My neighbor who is a welder was low/out of shielding gas so I decided to tackle this myself. Though not perfect, it is good enough to be passable for my needs.
I bought 3 cans of Eastwood High Temp Internal Exhaust Coating as I intend on coating the interior of my exhaust as far down the line as I can. I also used this as a coating on the welds and am in the process of curing it with a Mapp gas torch from the inside in hopes of it lasting at least a while.
I am still working out what to do for the rest of the exhaust, I had planned on pulling the 89 stock system completely off and using the exhaust from an LT1 to get the 2.75" piping and resonator. This fell through as my somewhat local C4 recycler turned into a flake and would not get back to me with a pic of what I was trying to buy, that is the second time he has done this, and he and I are done doing business. lol I may still go with the LT1 exhaust but will have to drive a little farther to pick one up. I know at the power level I will be running the 89 stock cat-back plumbing is more than adequate but not much more, and I do plan on a little more power in the future.
My plan as of now is a full 3" stainless pipe from the headers to a 3" Y-Pipe to a MagnaFlow 3" cat and from there the stock 89 exhaust. Even if I swap out that 89 cat back to the LT1 the parts from the cat to the headers would remain the same. I have my Amazon cart full of tubing, enough DEI heat shield to cover from the header to the cat and another set of V-Bands for after the cat.
The other thing I have done is pick up a complete intake system from a 90 C4, I got it all and only gave $250 for it delivered. That is TB, plenum, runners, lower intake, fuel rails, injectors and fastening hardware. These have been sitting in a box for a very long time. The TB shaft is not worn at all, something I did not expect. It is in better shape than the one I just put on a few months back so it may get swapped out soon. I have sent the runners out to be enlarged and have been studying porting the lower myself. It looks like a daunting task! I was going to go with ASM runners but they are out and gave me no indication of when they will have more in stock.
I am ok, just tired and low energy, that will last a few weeks and is normal. Prior to that I managed to get all of the exhaust measured, welded, coated and wrapped. I still have two small welds to connect the CAT to the rear "Y" pipe. I am a terrible welder, lol. I know, I accept it and I did manage to get everything sealed up. It took a few tries and I had to fill the pipes with water to check for leaks, I found several and sealed them up.
I had ground off the 3-bolt flanges because history has taught me they tend be a source of leaks. After being cut off I had the factory ends on the collectors that I then welded the V-Bands to, I made sure to keep the orientation of the exit the same, which was easy as the pipe still had the factory cut on it. What I did not realize is driver side would point in the wrong direction. I considered cutting the V-Band off and trying to correct the angle, and if I had a proper way to cut the pipe that may have worked. I chose to use a ball and socket joint instead, I dislike those as well but they tend to seal better than other designs. I even considered welding them at the right angle but it did not leak with numerous water tests so I left it, if I regret that down the road I can always weld them. I don't know if these were not made right or if the factory Y-Pipe was canted to correct it. The passenger side was correct.
The Y-Pipe welded up and mostly smoothed out. It took a lot of figuring and laying on my back to get this shape right and able to tuck up under the X-Brace.
The interior of the piping coated in the Eastwood product. This coating was really easy to apply, I sealed up all of the ends on the headers and Y-Pipe, poked a hole just large enough for the hose and sprayed into the pipe. Once I thought I had enough product in there I sealed up the small hole and rolled the headers and Y-Pipe around to ensure every thing got coated, waited about 15 minutes a rolled it around again to try and get the coating heavier, the stuff is kind of runny.
Some crappy welds and a decent one. I found I could not weld a circular pattern, could not keep a puddle and had to do a zig zag stitch or I would blow right through the thin stainless. Blow through happened far more than I wanted and fixing them meant a large blob to grind down. The blow through areas had more leaks than the rest. In the end it worked, even with a crappy little 110 welder.
The ugly one...
The "better" ones... (using the aluminum foil to shield most of the splatter worked quite well.) The O2 bungs turned out to be the easiest to weld, I was expected them to be the worst because of the thickness difference. I just kept the heat on the bung and quickly dropped it into the pipe. The bungs are 5" from the merge collector point, which should work well for a consistent reading.
The mostly finished setup. Design Engineering heat wrap and black silicone spray, aluminum heat shield over the "Y". I wrapped the headers where the factory shielding was lacking, no need to go all the way up the header tubes.
I cut the mounting flange off the gutted OEM Cat and welded in it onto the new MagnaFlow Cat. I only need to figure out the length of the short pipe between the Y-Pipe and the Cat and weld them up.
I mentioned I was going to send out the 90 intake runners to be punched out to a larger size, I did and got them back. They are roughly 39mm and finished nicely. A bit thanks to High Flow TPI for getting these turned around so quick. I won't install these until I take a shot at porting the intake lower and upper.
I am close to being ready to put this all back together. Things I ordered but have not installed, Summit branded split header bolts, I will be able to use most of these and I had to make room on the header tubes at the flange to get any header bolts in. Design Engineering spark plug boots and starter heat shield and ceramic boot spark plug wires. I will need to get a spark plug end tool to complete the distributor end but this will give me a better chance of routing away from heat. I have more aluminum heat shield to cover the top of the Cat with. I really wanted to do the entire tunnel with the DEI alum. heat shield but was not really interested in dropping the C-Beam and drive shaft and spending a week getting the tunnel clean enough for it to stick reliably. If the wrap doesn't control the temps well enough then I will have no choice but to do that. Given my current weakness I am glad I chose to not go that far this time around.
Great work...but don't give up on the practice welds...
I have had this little flux core welder a while now, it almost never get used and I am ok with that. One nice thing with an SMC car, you don't really get chance to weld on it. It is highly doubtful my welding abilities will improve and that is also ok.
