FS: Golen Ported LT1/LT4 Intake and Fuel Rails with Distributor Cutout For Dual Sync
This intake manifold was on my 1993 LT1 Corvette which had a Golen 383 with MSD Dual Sync SBC Distributor and Accel Gen 7 computer setup. It was ported by Golen and is port matched as well as drilled for a 58mm throttle body. It uses a standard LT1 gasket and fits LT1 and LT4 heads. The intake manifold bolt holes are elongated for easy install. The fuel rails have the fuel pressure port removed so you can fit a MSD Dual Sync Distributor. EGR is blocked off. This intake would be used if you wish to get rid of the optispark distributor forever and use an aftermarket computer. It could also be used to upgrade a TPI setup but I'm not familiar with the process. It has various small paint chips and it has two receptacles for a Manifold Air Temp sensor. Corvette Fuel Rails $125 , Intake is SOLD
