HV oil pump ...does not fit stock oil pan
I am sure the pump does, the pickup might not. However it seems the consensus of the forum, that due to the return rate of oil that some people running even 7qt pans have sucked air with HV pumps. Thus, you should try and run if anything, a HP pump. But if you run the HV, you really shouldn't be using a stock pan anyway.
Canton makes the right pan and pump and pick up.
The stock pick up is to long and the canton pan has scrapers and baffels ,trapdoor all that junk.Next is the crank balancer.
Been there done all that.
HV body touches OP not the pickup,,,not good..
thanks
Originally Posted by korvette4u
taken HV back to vendor, HP = high pressure?...i really didnt want HV ..but i think the new OP drive rod with the metal retainer is a keeper
thanks
thanks
The new "OP"=oil pump..drive rod. Yes definitly, the metal retainer is a keeper, you can also get one from ARP. They are definitly out there on the market.
So the High volume oil pump touches the pan?
Hmm a bigger pan could be mandatory. Should be with a HV pump anyway.
What did you take back to the vendor?
Received 1,401 Likes
I wouldnt be using the HV with a stock pan anyway.
Just get the M55-A, its High pressure and fits just fine.
which brings me to say, THANKS EVERYONE on this forum...sure makes my day
Cruise-In I Veteran
Originally Posted by olman
Stock oil pump is more than good enough according to John Lingenfelter. Who could argue with him?
So I'm here now fulltime to pester you guys.
