Backfiring when Accelerating, but no SES light...
Any ideas?
Also, when I disconnected the MAF Sensor, it didn't die, but the idle went up to about 1000-1200rpm and it was smoking (smelled like gas). I DID notice, however, that the sensor wires inside the MAF didn't glow when a friend shut the car off. (Aren't the supposed to glow red, meaning the Burn-off Relay is working properly?)
A while back, I got a Burn-off Relay SES Code, but it went away.
How does the car run at cruising speed, ie at 60mph steady..???
Here's a few things that comes to my mind:
- Fouled plug(s)
- Bad plug wire(s)
- Bad injector(s)
- Bad fuel regulator or pump
If your backfiring is taking place in your headers, this would indicate a rich condition in combustion chamber, which leads to incomplete burn during combustion cycle. The remaining "mixture" going thru the exhaust valve cotains enough fuel to re-ignite from your headers, which get really hot, and act as a "glow plug", causing backfire...
Either way if it was getting too much fuel, your plugs are gonna be fouled.
