100Hp mod for only $20
Old Mar 9, 2005 | 07:04 PM
FrankieD's Avatar
FrankieD
Default 100Hp mod for only $20
Can anyone tell me what an air breather is doing on a throttlebody??
http://img223.exs.cx/img223/3871/dsc093818pu.jpg
Old Mar 9, 2005 | 07:16 PM
4bblC4's Avatar
4bblC4
That looks like the Water coolant passage built into the throttle body, with a breather on it to make it look better than a piece of pipe sticking out into nowhere. it's a show car, can't have that as an eyesore.
i dunno, that's what it looks like to me.
Old Mar 9, 2005 | 07:20 PM
CFI-EFI's Avatar
CFI-EFI
Can't you post that picture a little larger? This one may actually finish down loading TODAY.
You don't beleive in air cleaners?
RACE ON!!!
Old Mar 9, 2005 | 07:58 PM
bogus's Avatar
bogus
my bigger question is "where is the oil cap?"
Old Mar 9, 2005 | 08:21 PM
Rynda's Avatar
Rynda
OOPs looks like he stuck it on the throttle body.
Those show and shine guys, ya gotta lovem.
(just kidding)
Old Mar 9, 2005 | 08:48 PM
Nathan Plemons's Avatar
Nathan Plemons
That's about the ugliest excuse for an LT1 I've seen in a long time.
Old Mar 9, 2005 | 09:09 PM
aboatguy's Avatar
aboatguy
I have seen uglier engines, however, those were old and abused. I have never seen anything so AFU on purpose. I really don't believe that this monstrosity was planned someone must have had some leftover baby $hit brown paint and or powder coat?
Although I will admit that I like the camel snot yellow.
Mike
Old Mar 9, 2005 | 09:23 PM
rrubel's Avatar
rrubel
There's a breather tube on MY throttle body (L98, yes, but it's there). A pipe connects it to the breather port on the rear of the valve cover, where he's got another breather element.
[RICHR]
Old Mar 9, 2005 | 09:26 PM
85 500 horse's Avatar
85 500 horse
RACE ON!!!
That's why you need to get on a high-speed connection - For those people who upload pictures way too big. It took my server 1-2 seconds to load it (Comcast Cable). It really does pay to go on broadband.
Old Mar 9, 2005 | 10:05 PM
MrNuke's Avatar
MrNuke
[RICHR]
that's what it looks like.
I removed that pipe also from between the valve cover and put on a breather on the valve cover and just put a rubber plug on the port on the tb.. Cleaned up the inside of the superram and the TB a LOT. No more oily sutt and crap in there.
Old Mar 10, 2005 | 09:48 AM
mseven's Avatar
mseven
show guys go figure
Old Mar 10, 2005 | 03:11 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Some of you guys are too quick to criticize everything. It's not my favorite colors by any means but I can appreciate anything that someone has poured that much detail into. That suspension is sweet. Guess I'm just a car guy.
Now as far as the little throttle body breather goes, I guess he felt that looked better than a plug. Not much function.
Old Mar 10, 2005 | 03:15 PM
Nathan Plemons
I'm sure it took a lot of time, skill, and money to make something that ugly. I'm sure somebody is very proud. You can't look at that and say it looks good. Top notch craftsmanship or not it's just plain ugly.
You've heard the saying "a rose by any other name is still a rose" well "ugly by any other name is still ugly"
Old Mar 10, 2005 | 03:26 PM
VAHROOM's Avatar
VAHROOM
Default I tried that same mod
I tried that same mod on my '83 Vette. I didn't get 100HP gain. I only noticed a 93 HP gain and my antifreeze leak caused a lifter gasket to fail. I don't reccomend it unless you have a F**D truck.
Old Mar 10, 2005 | 03:55 PM
MrNuke's Avatar
MrNuke
And you think that removing the air hose between the VC and the port on the TB did that?
Personally I wouldn't put a breather on the TB port itself as you'd be introducing unmeterd air on a MAF car to your intake.. Thats why I plugged mine up.
Old Mar 10, 2005 | 04:50 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Old Mar 10, 2005 | 04:55 PM
ClarenceT's Avatar
ClarenceT
lol, airbags are sweet huh? Ok, to each his own.
As for breather, the guy is retarded, plain and simple - cut those barbs off with a hacksaw and fill it in. That's what I did after ditching the heater hose, took roughly 30 minutes including removal and reinstallation.
RACE ON!!!
I agree, posting low res pics is almost useless. So much detail is lost. This one could use to be a meg or so larger. Ugly or not, that thing has a lot of detail that I do want to see in it's full glory. As for downloading today, your mistake is plugging your phone line into your computer
pS. What about air cleaners?
To 100Hp mod for only $20
Old Mar 10, 2005 | 05:13 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
actually I might get my fuel rail covers sprayed to match my car, I like the idea of painting those
Old Mar 10, 2005 | 05:32 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
He's using the later stlye fuel rail covers that don't have a notch for the breather line from from the throttle body. The vavle covers that were used with those FR covers had a whole in the side where the breather line would connect. Also, you wouldn't have to worry about unmetered air intering the intact. This is where cool was designed to flow. Hell, it might actually allow the throttle body to be a little cooler.
Old Mar 10, 2005 | 05:34 PM
Ramrod92's Avatar
Ramrod92
He's using the later stlye fuel rail covers that don't have a notch for the breather line from the throttle body. The vavle covers that were used with those FR covers had a hole in the side where the breather line would connect. Also, you wouldn't have to worry about unmetered air intering the intact. This is where coolant was designed to flow. Hell, it might actually allow the throttle body to be a little cooler.
