Lowering a '92
Mar 31, 2005 | 07:22 PM
Lowering a '92
What is the most inexpensive way to lower my '92, and also what way would you recomend?
Mar 31, 2005 | 07:36 PM
lowering
Quote:
mid america sells a front and back lowering kit for under a 100 bucks. although lowering the front requires removing the front spring. rear is simple, change out the bolts.
Mar 31, 2005 | 07:55 PM
How much would it cost, do you think, for a shop to do it for me? I'm not gunna touch my suspension.
Mar 31, 2005 | 07:58 PM
...also how much does this kit lower the car, and do you recomend it?
Mar 31, 2005 | 08:03 PM
You live in SoCal... I would not do it... for a couple of reasons.
1) It changes the effective geometry of the suspension. as low as these cars are, that effects the amount to travel.
2) SPEEDBUMPS. need I say more?
Mar 31, 2005 | 08:22 PM
I'll keep that in mind. I'm just looking into it right now. Thats why I want to know prices and whatnot.
Mar 31, 2005 | 09:30 PM
...anyone else have anything to add??
Mar 31, 2005 | 11:59 PM
Come on. I know more people have lowered their Vettes than this.
Apr 1, 2005 | 12:30 AM
Apr 1, 2005 | 12:34 AM
Quote:
Originally Posted by steve9899
Try a search.
I did. I couldn't find any that had opinions on the different kits. So I'm asking it here.
Apr 1, 2005 | 12:36 AM
oh, that's the only kit. Ecklers sells a similar part, as does all the other vendors.
The only other option is a $1200 coil over set.
Apr 1, 2005 | 12:42 AM
Ok cool. Thanks. Do you know about how much it would cost to get them installed (the $40 kit)?
Go For It
Dude the rear is nothing but a longer bolt and maybe 2 bushings if they come with them, take you longer to get the grime off of your hads when you are done. The rear suspension is actually very straightforward, I just replace almost all of my rear suspension bushings with polyurethane. You can do it! Just make sure you preload the spring just enough to release tension using a wooden block on a jack so you can control the springs release rate and you are golden.
Good Luck!
Doug
Apr 1, 2005 | 12:46 AM
Thanks for the adivise, but I heard the front is crazy hard, or takes like 6 hours to do.
Apr 1, 2005 | 12:51 AM
yes, that is correct. if I was to do the front, I would include things like bushings and ball joints. do it right...
Apr 1, 2005 | 01:57 AM
do it right...
EXACTLY why I don't want to do it myslelf.
