using Dana 36 Cbeam with Dana 44???
Old 03-31-2005, 11:20 PM
U_Dont_know
U_Dont_know's Avatar
Default using Dana 36 Cbeam with Dana 44???
hey guys,
did anyone try to use the Dana 36 cbeam with the dana 44, do anyone have pics of were you have to re-drill the wholes.
thanks
Old 04-01-2005, 12:23 AM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I think it was JoBy that did it. I forget, but I know he's over there in Europe somewhere.
Old 04-01-2005, 12:45 AM
REDC4CORVETTE
REDC4CORVETTE's Avatar
I don't know what you are asking?
If you are installing a dana 44 rearend and your car came with a dana 36 throw away the dana 36,C-beam, and drive shaft!
You need the C-beam from a dana 44 stick car and driveshaft from the same.
Old 04-01-2005, 01:12 AM
SHINOBI-X
SHINOBI-X's Avatar
JoBy from the Crossfire Injection vault DID use the D36 C-beam by re-drilling new holes.worked for him and saved some money.
Old 04-01-2005, 06:50 AM
95AquaC4
95AquaC4's Avatar
and the driveshaft just needs to be shortened about an inch or a little more.
Old 04-01-2005, 01:38 PM
CFI-EFI
CFI-EFI's Avatar
Not necessarily true. The D36 "C" beam is longer than the D44, because the D44 has a longer snout than the D36. You can simply drill two new holes in the D36 "C" beam in the proper location for the D44 and reuse it.
For the same reason, the D44 comes with a shorter drive shaft. It has been found, in many cases, that the longer D36 drive shaft will fit with the D44. Just make sure that there is some "slip" left at the slip yoke. Because the "C" beam prevents relative movement between the trans and the diff, less slip is necessary than on a car with a sprung (movable) diff.
Sorry.
RACE ON!!!
Old 04-01-2005, 02:07 PM
redbullapril23
redbullapril23's Avatar
you can get the driveshaft and the Cbeam for a dana 44 for like under $150. so I would just go ahead and buy it.
your friend
Sean
Old 04-01-2005, 02:32 PM
CFI-EFI
CFI-EFI's Avatar
Great! Buy them for me. That would be the preferred method.
RACE ON!!!
Old 04-01-2005, 04:22 PM
redbullapril23
i just got my complete dana 44 for 950. then c beam and driveshaft were an extra 100.
Old 04-01-2005, 05:03 PM
4bblC4
4bblC4's Avatar
can you take the dana 44 center section out of a jeep and use it then?
Old 04-01-2005, 07:30 PM
CFI-EFI
CFI-EFI's Avatar
No.
RACE ON!!!
Old 04-01-2005, 09:29 PM
Les 94 Comp Yellow
Les 94 Comp Yellow's Avatar
CFI-EFI Could you please explain why the 44 from a jeep and the one from a vette are not interchangable. Thanks
Old 04-01-2005, 11:41 PM
thmupr
thmupr's Avatar
I used a D36 C-beam when I did my swap. I' couldn't find a 44 C beam for sale, so I used the one I had. I had to re-drill the holes, and later I trimmed the end with a bandsaw to make installation and removal easier. I believe the holes were simply 1" back from the original, but I can't exactly remember. I'll try to get you a pic tomorrow, I have to change my fuel filter anyway..
Chris
Old 04-01-2005, 11:43 PM
U_Dont_know
Chris
thanks chris, thanks guys
Old 04-02-2005, 12:36 AM
ZD1
ZD1's Avatar
Chris
My knowledge base is limited by having a couple of jeeps and the vette. The Dana44 talks more to size difference from other models of differentials . The main reason why the center sections are not transferrable (viper, some hummers, corvette, and jeep) are that they are made to fit different applications. Someone may make the argument that the ring and pinion are the same, I don't know, but the cases are different. The jeep case (cast iron) is made for a solid axels, while the vette (cast aluminum) is made for "axel stubs" for the independant suspension.
To really get a hang on whats what, spend some time in the junk yard...
Old 04-02-2005, 03:45 AM
REDC4CORVETTE
The C-Beam mounts on the wrong side for the viper.
Just find the drive shaft and C-Beam ,you won't get as much clicking when you step on the gas.I would try Exautic vets.
And don't forget the liquid nails.
Old 04-02-2005, 06:26 AM
Mr Mojo
Mr Mojo's Avatar
For one thing, I don't think the Jeep housing would have the provision for the C-Beam
Here are some pics, the first two being Jeep, the second two, Vette
Old 04-02-2005, 04:18 PM
CFI-EFI
CFI-EFI's Avatar
All that and more. They are just totally different animals. The ring gears ARE the same size. Certain internals may be interchangable, too.
RACE ON!!!
Old 04-04-2005, 08:26 AM
trupp
trupp's Avatar
Originally Posted by U_Dont_know
hey guys,
thanks
I have a C beam and driveshaft left over from my 4+3 to ZF6 swap. I'm sure we can come to some agreement on price and shipping. I need to get these out of my garage.
trupp
To using Dana 36 Cbeam with Dana 44???
Quick Reply: using Dana 36 Cbeam with Dana 44???
