Ball joint - brand/source?
Old Apr 17, 2005 | 10:27 PM
reidry's Avatar
reidry
Default Ball joint - brand/source?
Ok so while I've had my '85 up on stands replacing u-joints, hubs, poly bushings, etc, etc, I just happened to notice the wear indicators on the front lower ball joints say it's time for them to go too. Car has 72K on the clock and the ball joints appear to be original (tops are still installed with rivets).
I am familiar with MOOG components so I checked the ususal sources. Rockauto.com has them for $65 (lower) and $68 (upper) coming to $264 plus shipping. Autopartsgiant has them in the 70s. So I thought I'd check Ecklers, Mad and Zip.
Ecklers has a front rebuild kit (Ecklers Part Number 43657) including the 4 ball joints and both tierod ends for $199, the sell single joints for $39.99. What's the deal are these things a name brand or junk? Mid America has a 4 joint kit for $129 and sells individual joints for $39.99. The have a complete front end kit with poly bushings and tie rods for $349.
My question is are the parts in these kits quality or not? Should I get a kit and save the $$$ or buy the MOOG parts elsewhere?
Thanks in advance.
Ryan
Old Apr 17, 2005 | 10:50 PM
Pete K's Avatar
Pete K
I would buy Moog locally.
Old Apr 17, 2005 | 11:00 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
How do you read the wear indicators? I've looked at mine a bunch of times and can't figure it out.
There's a notch in the steel around the zerk fitting...but what am I looking for?
Old Apr 17, 2005 | 11:03 PM
Pete K's Avatar
Pete K
The zerk fitting screws into a small nipple that protrudes from the ball joint base. If the nipple is even with, or below the surface of the base then replacement is needed.
Old Apr 17, 2005 | 11:25 PM
reidry's Avatar
reidry
I've got one even and one below even.
I'm leaning towards the Moog's already Pete. Thanks for the input. This is a driver/autocross car so it will get driven hard.
All advice welcome!
Thanks,
Ryan
Old Apr 17, 2005 | 11:35 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Nascar teams have run nothing but standard over the counter replacement Moog ball joints for decades, nuff said?
Old Apr 18, 2005 | 03:35 AM
goldeneye_vet's Avatar
goldeneye_vet
I went with the kit from www.powerperformancemotorsports.com. For the fronts including all poly bushings and joints and the outer tie rod ends for $220. I've not had a problem with them and believe them to be quality parts. I don't think however that they are a white box brand typical with generic or off brand parts. Installed mine last summer and am quite pleased with them. It doesn't help that you already have the poly bushings but maybe you could recoup some money and sell them on the net or through the forum to someone else. I liked this kit for what it provided and lets face it, you can dump all you want into this car and it is still only going to be worth so much $. Don't get me wrong I love my vette but I'm not going to spend an arm and a leg to get what it needs to keep her in great shape. Keep up on the maintainence like you are and she'll treat you right. Good luck and have fun with the new feel of your vette. You're going to love it!
Old Apr 18, 2005 | 10:30 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Do you have press to get the lowers in and out Their a biotch
Old Apr 18, 2005 | 10:58 AM
reidry's Avatar
reidry
<< Images Snipped>>
I have access to a 12 ton, ought to get'r done.
Ryan
Old Apr 18, 2005 | 12:33 PM
reidry's Avatar
reidry
So ... no one has ever used the Eckler or Mid-america kits?
Thanks,
Ryan
Old Apr 18, 2005 | 01:19 PM
VT Solo2's Avatar
VT Solo2
How about Vette Brakes? I'm using their ball joints on my 3rd gen F-Body, and they seemed to be pretty heavy duty. I haven't haven't priced them yet for the Vette, but that's what I'm going with when the time comes.
Old Apr 18, 2005 | 02:04 PM
reidry's Avatar
reidry
VBP (Vette Brakes and Products) is selling what they call "Heavy-Duty Ball Joints". Lowers are $79.95, Uppers are $79.95.
Still looking to see if anyone has used the Ecklers kit, sure is tempting to replace all four joints and outer tie rod ends for $199.
Thanks,
Ryan
Old Apr 18, 2005 | 02:45 PM
reidry's Avatar
reidry
Did a little research on my own. Called Ecklers and asked who makes the ball joints in that kit. The customer service person informed me they are purchased from Automaxparts. Their web site is under construction but they appear to be a distribution center for offshore products.
Read another article in the newsgroups about a Moog production plant burning down about a year ago and that Moog parts may actually be imported due to demand.
So many unknowns when all you want is a quality part.
Ryan
Old Apr 18, 2005 | 03:44 PM
JAKE's Avatar
JAKE
Originally Posted by reidry
I've got one even and one below even.I'm leaning towards the Moog's already Pete. Thanks for the input. This is a driver/autocross car so it will get driven hard. All advice welcome!Thanks,Ryan
I bought my Moogs from Pep Boys. You'll need to get the loaner tool from AutoZone, too.
Jake
Old Apr 19, 2005 | 09:05 AM
reidry's Avatar
reidry
BTT
Ryan
Old Apr 19, 2005 | 10:36 AM
CentralCoaster
Jake
The tool you need from Autozone is called the pitman arm puller. If there's two sizes, you need the large one.
Old Apr 24, 2005 | 10:37 PM
reidry's Avatar
reidry
Well I decided on the Moog ball joints. Didn't like the price, but much to my satisfaction the joints look good and are labeled "Made in the USA". Quality appears good. Started removing the front suspension today. Hope to have them done mid week, I'm glass beading and clear coating all my suspension members as I go.
Ryan
To Ball joint - brand/source?
Old Apr 24, 2005 | 11:36 PM
_twisted_'s Avatar
_twisted_
Is that for both uppers and lowers?
Old Apr 25, 2005 | 04:27 AM
CentralCoaster
So what you're saying is...
My left front lower ball joint is ok...
But my right front is toast...
Old Apr 25, 2005 | 07:49 AM
reidry's Avatar
reidry
Yep, right one is toast.
Both of mine looked like your right one.
Ryan
