wheel bearing question..
Old May 10, 2005 | 08:32 PM
1989redvette's Avatar
1989redvette
Default wheel bearing question..
my 89 needs a new rf wheel bearing what all years fit ?? is there a difference in the 84-87 because of teh wheel offset or are they all the same 87-96 > any different connections i need to be aware of for the wheel sensor ??? thanks in advance
Old May 10, 2005 | 08:34 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
It looks like 86-90 will fit the 89....
Old May 11, 2005 | 10:23 AM
TALMADGE's Avatar
TALMADGE
Changed mine on Friday, drivers side. I had replaced mine two years ago and the pass. side went south. I bought mine from Pep boys @ 139.00 apiece lifetime warrenty. They swapped the one out for me. Good thing the price now is 167.00 apiece. Easy replacement One big 36mm bolt and a T-55 torque bolt for the 3 bolts that hold the hub assy in twine. The tricky part it the 3 torque bolts. a little difficult to get to I used two different extentions together, made it alot easier.
To wheel bearing question..
