Need A/C Help: Solved
My '96 a/c was in the default position (no vacuum, blowing air only to the feet and windshield), but thanks to the help from the forum, I think I solved the problem. A special thanks to Hutch and ALLT4 for pointing me in the right direction and ALLT4 for his tips. I assume my problem was with the connection between the hvac programmer and the vacuum hose connector. After I trimed the plastic ****/nipples on the programmer like ALLT4 suggested, I reconnected the vacuum hose connector to the programmer and I got all the vents to work.
