160 Thermostat
Thanks for any help
JIMVET
If he does not now have the booster fan he will need to first remove (I hear it's a PITA to remove) the plug in the block below #1 & #3 spark plugs before installing the aux fan switch. Then he will need to route the wiring from that aux fan switch to the Grn wire going to the main fan relay, located below the brake MC at the rear of the left innner fender well.
Thanks for any help
JIMVET
RACE ON!!!
RACE ON!!!
Yes in warmer climates you need to turn the fans on sooner to take advantage of the cooler stat.
With the 160deg T-stat & complimentary fan on/off operation and a clean radiator temps will not hit 180deg F even in traffic in 95deg weather. And it will NOT take longer to reach the new operating temp of 160deg F. Running in summer heat with the A/C on may indeed cause higher coolant temps but that's a problem with the radiator, not the T-stat.
Yesterday I cruized several hundred miles in 95 deg heat with coolant temp holding at around 170deg F (A/C not on to the dismay of my passenger but she will get over it). Late in the evening, in 75deg temps, she was running 160deg F.
I highly recommend this mod for more power and lower under hood temps. Just tell your friend to be sure to change motor oil regularly and run a high quality full synthetic product.
RACE ON!!!
RACE ON!!!
Race on!!!
Race on!!!
In the above quote, you contradict yourself. In one breath you say, "Obviously a themostat can't hold water temp down if a radiator can't keep up." and in the next, you say, "If it is cool enough outside a 160 will keep a motor from running over that temp. So YES a thermostat CAN keep a motor from running hotter." Which is it? Are you saying that the stat controls whether it is "cool enough outside"???
The thermostat opens when the water reaches the stat's designed temperature. The temperature of the air has little or nothing to do with the stat opening. Once the stat is open...it's open. It's job is done. If the water temp tries to drop below the stat temp, the stat will close and allow the water to re-heat. The stat will maintain the minimum water temp. If the water temp rises above the stat opening point the stat does nothing. The stat CANNOT lower or help to lower the water temp.
RACE ON!!!
Race on!!!
Wrong. Sorry, you apparently don't know how thermostats work.Show me a Chevy small block that runs at, or near 160 deg F during normal driving conditions, and then, and only then, does your premise hold water. If an engine runs at 205 deg F after warmup period, then the coolant flow rate from a 160 and 180 deg thermo. will both be identical. It is only during initial warmup of engine that the 160 thermo. will begin to open sooner than the 180. But after 5 or 10 minutes of driving, the flow characteristics are identical.
CFI, you say I contridict myself, how so?
What is so hard to understand here? If it is a million degrees outside obviously the radiator cannot keep the liquid cool enough to allow the thermostat to close as the radiator cannot dispell the heat fast enough. If it is 0 degrees outside the coolant in the radiator will be cool enough so that when the stat opens it pours the coolant into the motor allowing it to cool enough below the 160 stats range so the stat closes. Thus the 160 stat WILL NOT LET A MOTOR HEAT TO OVER 160 DEGREES on cool days.
Damn you people really can't be this stupid, are you?
RACE ON!!
As I asked it my last post...WHICH IS IT???
If the outside were to be cool enough that the radiator can maintain the water temp at the thermostat temp, that is one thing. But it isn't the STAT keeping the temp down. The stat is keeping the temp UP. In air that cool, the stat MAKES the water reach the stat temp. If the stat were removed, the water wouldn't get even THAT hot. It isn't the 160* stat that keeps the water cool on a cold day, it is the air. If it weren't for the stat the water would stay cooler.
On the other hand, if when the stat opens and the air can't keep the water temp down to the stat temp, the stat has finished it's job, once it's open. After it opens at 160*, what's it going to do? Open again at 180*? And again at 195*? How does that keep the water temp any cooler?
RACE ON!!!
First you say, "themostat can't hold water temp down" and next you say, "If it is cool enough outside a 160 will keep a motor from running over that temp. So YES a thermostat CAN keep a motor from running hotter."
Good question...Tell us?
It isn't the stat that won't allow the engine to heat beyond 160* How does an open stat control the water temp?
We aren't, but if the shoe fits...
RACE ON!!!
Seriously I don't think you are this stupid and are just arguing because that is something you like to do.
How does a thermostat keep water temp down? If it is cool enough the radiator will be able to keep the coolant at a low enough temp that the motor won't overpower the radiators ability to keep the coolant temp from going over 160.
Where did I say that the stat is keeping the water temp down? IF IT IS COOL ENOUGH OUTSIDE THAT THE RADIATOR CAN DISPELL THE HEAT FASTER THAN A MOTOR CAN PRODUCE IT A STAT WILL ONLY ALLOW THE MOTOR TO HEAT UP TO THAT TEMP.
So how are those shoes fitting you tonight?
Race on!!!?
At the risk of repeating myself, which you claimed was wrong, the thermostat can only regulate how cool the engine runs. It has no control over how hot it runs.
RACE ON!!!
The thermostat DOESN'T keep the water temp down. The thermstat keeps the water temp UP! The flow of cool air through the radiator is what keeps the engine cool.
In the quote, in the last paragraph and in post #9, "So YES a thermostat CAN keep a motor from running hotter."
RACE ON!!!
Like I said, you just argue to argue. Go out and get laid, it may release some pent up hostilities.
Race on!!!!
motor overheating we could just pull the thermostat out and because the coolant would be constantly running the loop it would keep it cool,
and thoughs were the days when fans ran constantly-WRONG! It may have taken a little longer for the engines to heat up-but did nothing to
control the temps after that point.Obviously outside temps, the load on engines do play a factor-most have witnessed temps being equal an engine may heat up while climbing a hill-but will cool on descent-like wise I'm sure most have at one point seen a car along side the road in freezing temps with the hood up and steam coming out do to over heating.160, 180 or anyother heat range thermostat MAY control what
temps an engine will reach ONLY if all components (fans, etc) are functioning properly, in conjunction with outside temps.
I am convinced, at this point that YOU are the one that wants to perpetuate a conflict without basis. You have also convinced me that YOU are too stupid (your word and initial accusation) to not understand how the thermostat and cooling system work, but also not bright enough to listen to logic and facts. Good luck in your fantasy world.
RACE ON!!!
