Rearend Q's
Old Jun 14, 2005 | 12:35 AM
65coop's Avatar
65coop
St. Jude Donor '05
Default Rearend Q's
I have a '90 Automatic with the D36 and the 2.73 ratio - My question is...
Is there a better ratio for the D36 (3.55 or 3.73)? Or... Will I need to find a D44?
Also, I think I was told or read here on the forums that the D36 to D44 swap required more then just the "batwing" to install.. yes / no?
If so, can anyone supply me with a parts list or direct me to one or... maybe someone who has everything I need to do the swap
Thanks for the help
Old Jun 14, 2005 | 12:38 AM
scorp508's Avatar
scorp508
D36 to D44 swap requires...
Dana 44 Differential (Pumpkin & Batwing)
Dana 44 C-Beam
Manual transmission Driveshaft (~1" shorter than yours is)
I don't think your 2 series D36 carrier can get a shorter gear. If you had a 3 series carrier (3.07s) then you could go up to a 3.73 I think. I don't know if you've done anything to your car, buta stock L98 really won't benefit from anything over 3.07s.
Old Jun 14, 2005 | 12:48 AM
65coop's Avatar
65coop
St. Jude Donor '05
The car has headers & no cats, SR intake, 24# injectors, 1.6 RR's, 52mm TB, custom chip - It runs good, but I want better...
anything better than a 2.73 has got to help... once it gets rolling it runs great.
So... what do think? Look for a D44 w/ 3.73's?
Old Jun 14, 2005 | 12:51 AM
65coop's Avatar
65coop
St. Jude Donor '05
One more thing... If I do a shorter gear, how do I correct the speedo?
Old Jun 14, 2005 | 12:58 AM
scorp508's Avatar
scorp508
I'd look for a D44 with 3.45s with that setup. The speedo is corrected with purchasing new 'speedo gears' that get installed in the tailshaft of your transmission.
Old Jun 14, 2005 | 01:31 AM
sami85L98's Avatar
sami85L98
check this one in parts sale section for D44 :
http://forums.corvetteforum.com/show...02&forum_id=55
Old Jun 14, 2005 | 01:37 AM
vader86's Avatar
vader86
3.73 is too much for the automatic, 3.33s would be good if you can find them, 3.07s are all the SR or the L98 needs though.
Old Jun 14, 2005 | 02:12 AM
SHINOBI-X's Avatar
SHINOBI-X
i got a 3.07 D36 for sale. PM me if you want it for cheap, i need the space and don't need a extra rearend.
Old Jun 14, 2005 | 08:30 AM
mikey whipreck's Avatar
mikey whipreck
you should be able to find a D36 with a 3.07 rear... (mine has one)
You might also want to look at some '84's. They came with a 3.07 rear standard, and the 'performance' RPO'd cars came with a 3.31 D36 (or was it a 3.33).
Old Jun 14, 2005 | 08:42 AM
scorp508's Avatar
scorp508
I'm sure someone will correct me, but in '84 wasn't the 2.59 standard, the 3.07 "performance ratio" and 3.31 optional only if you had Z51?
Old Jun 14, 2005 | 08:55 AM
mikey whipreck
not according to my '84 helms... unless I'm reading it wrong- which wouldn't be the first time...
Where's CFI-EFI when I need him?
Old Jun 14, 2005 | 09:52 AM
CFI-EFI's Avatar
CFI-EFI
Rat Cheer!
The 3.07: ratio (RPO# HE3) was the standard ratio in 1984, standard or automatic. The 3.31:1 gears (RPO# GW4) were the "performance option" for the '84 and required the Z51 handling package. The Z51 didn't automatically come with 3.31's. Most were built with the 3.07's, but Z51 had to be specified to get the GW4. The 3.31's are pretty rare. Out of 51547, 1984's built, 410 were equipped with the 3.31 gears.
RACE ON!!!
Old Jun 14, 2005 | 10:54 AM
mikey whipreck
Originally Posted by CFI-EFI
Rat Cheer!
RACE ON!!!
Cool- I wasn't sure how they were optioned, but I was pretty sure that the gearing was either 3.07 or 3.31. I didn't realize the 3.31 was that rare though...
Old Jun 14, 2005 | 11:43 AM
CFI-EFI's Avatar
CFI-EFI
The option code GW4 is listed as good for 1984 and 1985, only. I don't have the 1985 info, that I do on the 1984. Therefore I can't confirm or deny if the 3.31's were available in 1985 or not. I do know that GM and Dana discontinued the 3.31 gears, early on. The 3.33 is a Dana 44 ratio.
RACE ON!!!
Old Jun 14, 2005 | 11:53 AM
vader86's Avatar
vader86
84 was the only year for 3.31, 89 got the D44 3.33 in some ZF6s.
To Rearend Q's
