Rusty front Y pipe bolts
Old Jun 18, 2005 | 09:46 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Default Rusty front Y pipe bolts
I`m changing the front Y pipe on my `87 to one without the pre-cats, & a high flow convertor. Has anybody got the stock manifold to Y pipe bolts out without snapping them?. I`ve sprayed the heck out of them with PB Blaster, & LRP 100, but they are still pretty tight. I`ll try loosening them tomorrow after they have soaked overnight. Just wondering if I`m wasting my time.
Old Jun 18, 2005 | 11:47 PM
91vettemo's Avatar
91vettemo
this is what i'm just about to finish up on. I replaced my front Y pipe to one without precats, then put in a high flow cat, and put on some muffler eliminators. I thought it would be to loud, but I love how it sounds. But to your question, mine just came right off. Only other thing to try is to heat them up if you can. Good luck.
Old Jun 18, 2005 | 11:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A copla years ago I just hit my front Y-pipe bolts with PB Blaster, let them stand overnight, hit them again in the morning and they all came off without any breaking. I had to put a pipe over breaker bar to loosen a cople of them.
In any case, if you break on just pull the stock header. If that happens it is somewhat of a PITA time wise but not difficult.
Old Jun 18, 2005 | 11:59 PM
kenv's Avatar
kenv
St. Jude Donor '10
Thanks-- hope mine does the same. I got the pipe from the local corette recycling yard for $75.00, & it came with a fairly new cat.
Old Jun 19, 2005 | 12:07 AM
65Z01's Avatar
65Z01
Good deal, if you have a hi-flow cat-back you should get some nice gains from the new front Y & cat.
To Rusty front Y pipe bolts
