Need help with 2 grounds driver rear (Pics)
Old Jul 20, 2005 | 11:37 PM
mothersworry's Avatar
mothersworry
Default Need help with 2 grounds driver rear (Pics)
I am having trouble locating where these two ground wires connect and help would be appreciate. My car is a 92 coupe. Below are the pictures of the grounds:
Ground 1
Ground 2
Old Jul 20, 2005 | 11:57 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd hook them to a ground! Just kidding. I'm having trouble telling exactly what part of the car the first pic is. The second one looks like it could be one of the antenna grounds.
Old Jul 21, 2005 | 12:05 AM
mothersworry
The first picture is the Drivers side rear where the body meets the bumper fascia. Hope this helps.
Old Jul 21, 2005 | 12:29 AM
Corvette Kid
Aha! Does the other wire in pic one go to the antenna? If so, hook both of them to to same facia bolt. The wire in pic two should also go to the antenna and then go forward to somewhere on the frame I suppose. Anyhow, this string of grounds should ground things in the rear, the antenna etc.
Old Jul 21, 2005 | 09:28 AM
mothersworry
I see now how they go. Corvette Kid you are right These ground at the antenna bracket and then the antenna and bracket assembly is groundd to the frame. Thanks for all your help.
mothersworry
I see now how they go. Corvette Kid you are right These ground at the antenna bracket and then the antenna and bracket assembly is grounded to the frame. Thanks for all your help.
Old Jul 21, 2005 | 10:50 AM
86C4EVER's Avatar
86C4EVER
On my 86, there is a "tortion" bar that goes accross the back, just forward of the fuel tank (2-3"). This is a solid bar. (Not the one mounted onto the rear dif. cover). It is bolted on either side with two bolts, one front and one back. My grounds are mounted on the back bolts.
Hope that helps.
Fred
To Need help with 2 grounds driver rear (Pics)
