Looking at 383
The heads are another story but I will most likely go with bob at precision porting after for that.
The car is a daily driver and will not see the track; only street reacing on occasion.
The one I built was a SCAT cast crank, with probe forged rods and pistons. Pretty budget minded, and could of lived forever at the power levels I pushed through it.
Eagle Forged 6 Inch I beam 5140 rods
Crankshaft Scat 4130 cast
Prety good price. one can pay to the moon for some brands of these parts, but it may not be necessary for your needs.
its all to his own opinion but since currently im building a 383 right now im sticking with some scat products and some hyperuetectics from federal mogul. nothing special for a 84' crossfire but if i was making a high winding 355 11.1 compression,solid roller cam,210cc+heads meant to see 6000RPM+ all the way down the track i'd choose CROWER bottom end parts with J/E pistons.
JMHO guys and gals
For what you want, all cast.
But I do want to recommend to you file fit rings. Do not trust the "pre-gapped" rings. If you do get them, fit them into the individual cylinders they'll go into anyway. Cast iron is plenty fine.
Take the extra effort to balance everything inspite of someone telling you "it's already balanced". Including the flywheel and harmonic balancer.
What year car is this?
Go Fast Parts
The guy seems pretty knowledgeable and doesn't mind answering questions.
Hey Neat, I see your 92 had huge RWHP. Was that a 383?
as far as neats rwhp.. im sure he said it was on spray.
JE forged pistons
Eagle forged crank
Manley forged rods
10:1 compression
Heads are already Stage III ported, but they are opening them up a little more. Already have a pretty big cam.
Can't wait to get her back!!
im building a 396 now.
eagle forged crank
lunati billet rods
srp nos pistons
comp cam 256/260 @.050 solid roller. 650/650 lift
brodix m2 215 cnc heads.
estimated hp 625 fw. + 250 shot.
eagle forged crank
lunati billet rods
srp nos pistons
I can't count how many people have emailed/IM me about either our 406s or 434 combos, asking if I thought it would go as good with say a set of AFR heads, or edlebrock heads. The answer is pretty simple - You won't know until you try it, but I can assure you that if you match it, and everything is done right in the buildup - it should go every bit as good.
Don't get me wrong, I don't want to discourage anyone from experimenting - but trust me. I do lots of that and it costs lots of $ and lots of TIME. And most of the time, the results are very minimal. Once you get a good setup, its tough to gain much more over what that setup can physically make. You can however "fine tune" to make it incrimentally better. For example, with Jerkyboys 434 combo we did, we instilled everything we have learned off ours into it, plus a few "fine tuning" items that should make it actually faster. But following that recipe for a 434 we could produce 100s of them that would all run within 10hp of one another. As before mentioned, its not magic.
On the side of parts, your bottom end of the motor needs to be strong enough for what your trying to do, with some safety factor. The rods being the piece that is factored the most since they take the brunt of the abuse. The pistons and crank follow thereafter. Pistons can be a PITA, so I do not chince on them (forged all the way). Rods as previously mentioned need to be good (forged and GOOD brand), while cranks you can get away with more. There is power in the crankshaft (lightweight), but you will pay BIG bucks for these pieces and a spun bearing can cost you LOTS of money in a big hurry, therefore my thoughts here are to go middle of the road. Eagle makes very good pieces that are good to 1000hp, and are remarkably at low prices. <500 dollars. You can get a crower, and pay 3k for it, and it will make more power than the eagle crank most likely, but may drive you to the grave if something small happens to it.
So in the nutshell, I would make the bottom end for a lack of better words "disposable" - that term is being use very loosely here, so don't take that litterally.
The heads are where the power is truely made. Good heads = good power per CI. There is no way around this. You need two things to make power, air and fuel. The fuel is the easy part, the air is the tough part. The more air, the more power. So get the absolute BEST heads you can afford to buy and you will be lightyears ahead. Build a killer bottom end with all the best part, and put a set of box stock dart heads on the motor and it will make virtually laughable power. Put a good set of heads on it, and it will gain 100+ HP. More air= more power.
My suggestions are as follows. Find a good combo and match it. If your experiementing on a new combo, your budget should look something like this.
30% bottom end 70% topend = good motor
The common problem I see is most guys do it this way:
70% bottom end 30% topend = lousy motor
Hope that help you out. When it doubt, the best rule to follow(this is not school) is to copy.
As a side note this is why most crate motor builder hold back information such as cam designs and other aspects of the motor. They find a combo that works well, and they hold those secrets near and dear - otherwise every other builder will also use them.
Without going pressurized, you may not like the side effects, though.
Keep us posted.
Larry
code5coupe
J&E pistons
oliver rods
Hank the crank crankshaft
For the top end I wish for a set of SB2.2 heads.
Unfortunatly the reality is:
I have eagle crank and rods
SRP pistons
check it out;
http://web.camaross.com/forums/showthread.php?t=382538
and stock heads that were ported by me.
J&E pistons
oliver rods
SRP pistons
check it out;
Aren't JE and SRP the same pistons? They are made at the same place, and than just boxed differently??
Um...I think you really meant street "revving" or "rolling", because none of us here on the forum street race, and we all know that those posts are not allowed
But yes Sportman racing product pistons are made by J&E.
I almost posted this in my last post but I thought nah, I dont think anyone would be too pickey.
