trailing arms - which ones?
Old Aug 23, 2005 | 09:07 PM
ericcer's Avatar
ericcer
Default trailing arms - which ones?
I know the adjustable rod end types are the best for performance. However, I had some on another car one time but found them noisey (transfering road noise to the cabin) and the rod ends started to wear out and klunked. Can I expect the same if I get them for a Corvette? One guy said that they weren't that noisey.
Old Aug 24, 2005 | 10:48 AM
ericcer's Avatar
ericcer
What, no opinions on this?
Old Aug 24, 2005 | 10:57 AM
1991Z07's Avatar
1991Z07
Had mine on the car for 5 years...got them from Vette Brakes. Have the camber rods as well.
No issues with noise at all. I keep them lubed at an interval of every 6-8 weeks when I'm driving it to keep the ends from wearing out so fast.
A small grease gun with a flex-hose on the end is great for this...(when you don't have a lift to put the car on).
Old Aug 24, 2005 | 11:38 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Every person has a different tolerance for "noise".
Even the sellers of these components will tell you they are not for street use, for the very reasons you mentioned: noise and fast wear.
Since you've had spherical rod-end parts before, you know what to expect. It's all in what you are willing to tolerate.
Larry
code5coupe
Old Aug 24, 2005 | 12:26 PM
vader86's Avatar
vader86
I'm looking at all the new parts listed in the VBP catalog for my rear suspension, so are all these upgraded 'racing' parts that noisy? I'm basically looking at EVERY part in the catalog for a car this old.
I have a nasty clicking/clanking sound when going over bumps coming from the rear suspension, sounds like metal/metal contact and its driving me nuts because there are potholes every 2 feet in Baton Rouge. I want it quieter.
Old Aug 24, 2005 | 12:46 PM
rocco16's Avatar
rocco16
Originally Posted by vader86
I want it quieter.
So did the design engineers.
That's why they gave (and still give) the Corvette bushings made of rubber.
Larry
code5coupe
Old Aug 24, 2005 | 12:52 PM
vader86's Avatar
vader86
Rubber bushings are out of the question, I want those in polygraphite.
If something needs frequent lubing, thats doable, but if its going to crick/clank all the time and destroy my confidence in the rear, I dont need it.
Old Aug 24, 2005 | 02:37 PM
ericcer's Avatar
ericcer
That would be somethig I could deal with to. Still I would like to hear more opinions on the use of rod end instead of rubber and poly.
Old Aug 25, 2005 | 03:05 PM
MarkBychowski's Avatar
MarkBychowski
When NEW, heim joints (spherical rod ends, whichever you prefer to call them) don't make any noise. The clunk comes after you've driven with them for a while and they've worn down. I run heim ends on my rear camber rods and they've held up fine on the street for the past 3 years, but I only put maybe 2K-3K miles on it each year.
If the car sees a good deal of normal street driving, I'd recommend sticking with poly if you don't want rubber.
Old Aug 25, 2005 | 04:31 PM
2manyfuncars's Avatar
2manyfuncars
Rod end longevity is also affected by the quality and materials of the rod ends themselves. You can add seals to protect them from water too. High quality telfon lined chromemoly rod ends will last a lot longer than the economy types that some suppliers provide with their linkages.
I run only certain brands and use the largest possible rod ends with very tight fitting reducer sleeves.
Good luck
Old Aug 25, 2005 | 04:42 PM
1MoorTym's Avatar
1MoorTym
When I did my rear over, VBandP advised me to use poly on the street and to stay away from the spherical's because of the maintenance required. I followed their advice and have been very pleased with the outcome.
I also appreciated the fact that they steered me away from a product that cost more for the right product for my application.
Old Aug 25, 2005 | 08:23 PM
vader86's Avatar
vader86
So are VBPs Racing-version parts usable on street cars, or do you want the HD-version? Whats the real difference in these parts?
Old Aug 26, 2005 | 06:28 PM
1MoorTym's Avatar
1MoorTym
You can use them on the street, but as explained to me, the racing pieces are more typically used for shorter durations of extreme duty and because of that are generally serviced (cleaned and lubed) more frequently. Used on the street, they would probably see more usage and less service leading to premature failure or less performance than the reason you bought them in the first place.
I think the only HD piece they make is the tie rod, struts are desginated "racing" or "racing smart" with the racing smart relocating the strut end for a better control angle. Then of course there's the poly strut in both flavors as well...
To trailing arms - which ones?
