Throttle Problem "You Won't Believe This One"
Old Sep 11, 2005 | 11:54 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by 1986vert
Believe it or not the problem is the throttle body, it was not going to the stop all the time when I let off the gas, so I put a bandage of a second spring until I find another throttle body. Thanks for all the help and suggestions.
I believe it. That comes as no surprise here. I was just waiting for all the final reports with the throttle and cruise cables disconnected, the brake booster out of the picture, etc. to reiterate. As I first said, the TB casting is worn where the throttle shaft turns in the pot metal casting. There ARE specialty shops that can re bore, bush, and seal, those worn shaft bores.
RACE ON!!!
