Reconditioning Rims/Wheels
Old Sep 20, 2005 | 12:59 PM
Bob CTS's Avatar
Bob CTS
Default Reconditioning Rims/Wheels
I might be in the wrong section, but does anyone know of a company that can refinish the wheels on my 86, these are the stock rims, I guess I would like them buffed, repainted in the vent slots and then clear coated. I have tried the over the counter stuff and nothing really seems to help. Thanks.
Bob
Old Sep 20, 2005 | 05:32 PM
mfi's Avatar
mfi
They are in NY so shipping might be expensive
Als Hub Caps
490 jericho tpk mineola ny 11501
516-742-6823
1800-836-9053
met the owner at a car show, seemed to know a lot about vette's.
Old Sep 20, 2005 | 06:13 PM
dwestsr's Avatar
dwestsr
I simply stripped mine with Aircraft grade alum stripper and polished with a buffer and metal polish. That was six months ago and they still look great. Just a little polish now and then.
Old Sep 20, 2005 | 07:40 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Transwheel in Huntington, IN - Good work but may be pricey though.
http://www.transwheel.com
Old Sep 20, 2005 | 08:46 PM
DanZ51's Avatar
DanZ51
Aren't '86 wheels natural aluminum finish in the wheel vents. I thought just the '84-'85 were painted.
Anyway, strip them (it's not hard). Then clear coat them or buff them. I used an old vette wheel bearing and mounted it on a "buck" so I could spin the rim while I sanded and polished mine. Now they shine like chrome. THAT was a bit of work But I guess worth it considering the compliments I get...
Don't bother trying to clear coat a (highly) polished rim. The clear won't stick. I've tried (twice)
Old Sep 20, 2005 | 10:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
Do it yourself, its really not bad at all.
http://forums.corvetteforum.com/show...ed&forum_id=34
Old Sep 20, 2005 | 10:24 PM
Pete K's Avatar
Pete K
Wheel Collision Center in Bath Pa. will sell you reconditioned rims that are equal to, or better than new for approx $125 each outright.
Old Sep 21, 2005 | 07:16 AM
Bob CTS's Avatar
Bob CTS
Thanks a bunch I will check into each source, the 86 vents have a light gray finish in them opposed to the black in earlier models, this gray is comming off in certain areas which led me to think it was paint.
Bob
Old Sep 21, 2005 | 07:39 AM
Pete K's Avatar
Pete K
The argent gray paint you describe means that the wheels are 87. 84-85 were black, 86 was natural, 87 wheels are gray. You can strip the paint off the 87 wheels to make the correct look for 86. The wheels are all the same from 84-87. They do have different widths. 8.5 and 9.5.
Old Sep 21, 2005 | 03:26 PM
Mad-Mic's Avatar
Mad-Mic
i did my own. you can read here about it.
http://www.cardomain.com/ride/428980/8
Old Sep 25, 2005 | 01:21 AM
JETSET's Avatar
JETSET
Default Ceramic coating
We can ceramic coat your wheels.
It look like polished stailess steel when done properly and won't crack like chrome.
Also helps dissipates the heat from the brakes.
http://www.racevision.com/products/p...glow/index.htm
Old Sep 25, 2005 | 09:00 AM
mikenfl's Avatar
mikenfl
I just finished the stripping, sanding, polishing, painting thing. My '85 is down off the jackstands for the first time in over 2 weeks. I still have to clean up and install the lugnut covers and give the car a good bath. I polished the "face" of the wheel and repainted the slots and center black with POR 15 Topcoat. Regular spraycan wheel paint doesn't seem to hold up well to wheel cleaner, so I thought I'd try the POR 15. We'll see. It was alot of work in terms of time, but not difficult. I didn't reclear. It's not a daily driver and sleeps in the garage, so a little polishing once in a while won't be a big deal. The biggest PITA was masking it to paint the black areas. I did find one thing that was interesting. I ordered some POR stripper along with the paint. It's sprayed on with a squirt bottle. I also had some aircraft stripper already. The POR Strip was much faster acting than the aircraft stripper, which suprised me. Great stuff. I'll post pics once I get her cleaned up.
To Reconditioning Rims/Wheels
