How would the following affect performance?
Would it drop ET by 0.54 and up MPH by 1.4 MPH?
Heres what I was thinking...
Drop 140 lbs. = 0.14 sec and 1.4 MPH gain
Drop 0.2 sec (60 ft.) = 0.4 sec gain
0.14 + 0.4 = 0.54 sec and 1.4 MPH
Right? Wrong? Close?
....true
....maybe 0.3sec gain
...so 0.14 + 0.30 = 0.44 sec and 1.4mph
Assuming weather is the same as on the baseline runs.
seems about right, but maybe dropping 0.2 might gain closer to 0.3-.035
It depends on how you go about reducing your 60ft times.
If you just improve your launch technique, then the .2sec gained at the start just puts you .2sec closer to the end of the track and your total et improvement will be .2sec.
If you gain (lose, actually) that .2sec through a power increase or better bite through first gear, then who knows what your betterment in et will be...but whatever it is, it won't be from improving the 60ft times;
the improved 60ft times will be a result of what creates a better overall et, it's not the cause.
Cause and effect, cause and effect.
Maybe someone can explain the apparent importance of 60ft times. Why not 120ft times? or 1000ft times? or...gulp...1320ft times??
Is it just a convenient distance that has become a standard?
I'm thinking that is the answer...
Larry
code5coupe
