Rear rotors
Old Oct 4, 2005 | 06:17 PM
the blur's Avatar
the blur
Default Rear rotors
I went though this before, and I can't find my notes.
The 96 FSM says 166 ft-lbs for the rear rotor caliper bolts. I busted the bolts listening to the FSM once before.
Does anybody know the correct torque spec for the rear caliper bolts that hold the rotor in position.
I think the eariler service manuals were correct, and in 96 they used the front spec for the rear....
Old Oct 4, 2005 | 06:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm thinking the 166 may have been for the caliper bracket bolts and that seems a bit excessive, even for them. What diameter are these bolts? I can't remember. If they're 8mm, I wouldn't go much over 20 lbs., if they're 10mm, maybe 30-35 tops would be plenty. Admittedly, this isn't the kind of thing I would generally get a torque wrench out for so I've never looked it up.
Old Oct 4, 2005 | 06:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My '88 front caliper bolts only call for 137 lb-ft and the upper rear caliper pin bolt takes 26 lb-ft, the lower bolt takes 16 lb-ft and the caliper bracket bolt takes 70 lb-ft.
To Rear rotors
