Quick weight removal questions!!
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by 65Z01
My '88 sport seat & track is worth maybe 40lbs or so, pretty heavy assembly.
Spare & jack could be another 40-45lbs.
Dropping from 3/4 tank to 1/4 tank of fuel is worth about 60lbs.
These should be worth 1.5sec reduction in ET or more properly increase in trap speed.
Larry
code5coupe
Question regarding this old thread, why the PC680 an not the PC625? Ligther and cheaper $!
[/QUOTE]
The PC680 has alittle more capacity as I remember. The PC625 might work just as well. Also use battery tender.
As an update to this old thread, I now race with 3/4 tank of gas. My 60' and ET's are better and more consistent with the added weight in the rear. MPH is down a little though.
I removed the fuel tank and put a 5 gal cell in the back. Good to the last drop. Don't have to run 5/8 tank of fuel anymore. Just got done removing the front bumper and removed exactly 20 lbs of crash stuff up front. Can't tell after replacing the bumper. Can't go head first into the wall though.
