Timing cover leaking at oil pan
Just finished a water pump/opti/timing chain and gears on a 1994 LT1. Serious leak at the oil pan and timing cover. I'm not surprised, the cover was tough to replace and no way to observe the gasket. I guess dropping the pan and replace gasket is next step. Any suggestions would be appreciated. Thanks...DB
St. Jude Donor '03 & '05
Originally Posted by steve40th
Drop the pan and put a dab of Rigth Stuff RTV at each corner of the pan. The gasket will be fine unless you rip after dropping it. Shouldnt take more than ahour to do it. I just went through this and even though Fel Pro said it is a Dry gasket, it leaked, and I put Right Stuff in each corner, and voila, dry!
Thanks for the info. Will I find Right Stuff RTV at an auto supply? The gasket came off with the cover, so I'll be replacing with a new pan gasket.
how do you guys get the pan on and off??? my experience was that i had to unbolt the engine and raise it a little to get the pan on and off.
any help/tips would be greatly appreciated
Also does anyone have any experience with the "KWIKLIFT" drive on ramp system for getting the car off the ground and level?
Yeah, that's a real good question... I was under the car and looking to see if the pan would come off without raising the motor. Looks like it will although it looks like the exhaust needs to come loose to get the bell housing dust cover out of the way. If I have to move the exhaust then I will go ahead and install some headers and a different exhaust system (maybe ... any suggestions??).
Take your time too, and dont overthighten the pan bolts.
dbaction
check out this thread about the kwiklift
http://forums.corvetteforum.com/show...light=kwiklift
I love mine.
Had it for years
www.kwiklift.com
I love mine.
Had it for years
www.kwiklift.com
Just unbolt the motor mounts the bottom, 18mm nuts, jack the motor up at the tranny a couple of inches. Thats all you need. Take the didpstick tube out too. The starter needs to be unbolted enough to move it out of the way, no need to take it out. Then the pan will come down easily, if not, thenone of the throws on the crank may be hitting the pan, then turn the motor over with your hands on the flywheel/flexplate.
Originally Posted by 56chevy
dbaction
I love mine.
Had it for years
www.kwiklift.com
I love mine.
Had it for years
www.kwiklift.com
