HELP with Wheel Bearings!
Old Dec 12, 2005 | 10:13 PM
99SoCalFRC's Avatar
99SoCalFRC
Default HELP with Wheel Bearings!
Can wheel bearings on a C4 actually freeze? A friend of mine just had a C4 towed with a intermittent locking of the left front, some movement (rotation) in reverse, next to nothing in drive? What could this be? The car does have around 160K on the clock?
Old Dec 12, 2005 | 10:17 PM
Pete K's Avatar
Pete K
Pull the brake caliper off and spin the wheel. If it gets looser, it is a locked up brake caliper. If not, it is the wheel bearing.
Old Dec 12, 2005 | 10:18 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Never heard of a wheel bearing locking up but it could be something to check.Other causes are seize brake caliper and or the brake hose.
Those are what I would check.
Great White North's Avatar
Great White North
I may be wrong but the wheel bearings are so mickey mouse I think they would fall apart first.Maybe a seized caliper?(just my 2 cents)
Old Dec 12, 2005 | 10:19 PM
Pete K's Avatar
Pete K
Once I had a chunk of rubber recap kick up and get between the caliper an rim. This locked it up. Check all the obvious stuff first.
To HELP with Wheel Bearings!
