need help!which sensor is it?
while puttin on headers I broke a switch(sensor)near #1 cyl. near spark plug, is this imp. to runnin of car, it seems ok. :smash:
Re: need help!which sensor is it? (88sk)
I think that would be the auxilary fan switch. It won't work until you replace the switch. You probably don't need it.
Re: need help!which sensor is it? (Sarkee)
That is the aux fan sw which turns on the aux fan at 238 F. I would repair the broken wire so that you will have the added cooling should your engine get to that temp. Might save the engine some day. :bb
