aux. fan relay question
Old 08-05-2001, 09:29 PM
dt35th
dt35th's Avatar
Default aux. fan relay question
Cannot find aux fan relay. have 1988, hayes manual says that they are located on left side of shroud, but I have only one relay there. Does anyone know where other one is. Thanks
Old 08-05-2001, 09:37 PM
jfb
jfb's Avatar
Default Re: aux. fan relay question (dt35th)
The aux fan relay is behind the LH parking light. Follow the aux fan wires and they will lead you to the relay.
Old 08-05-2001, 09:42 PM
dt35th
dt35th's Avatar
Default Re: aux. fan relay question (jfb)
I followed wires to a plug & harness but did not see a relay, is the area you are talking about by front of car
Old 08-05-2001, 09:58 PM
jfb
jfb's Avatar
Yes, the front of the car. The relay is just to the left of the headlight and the plug/connector you found has two wires that go to the fan relay. Keep following the wires after the plug/conn.
Old 08-05-2001, 10:33 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
The one you found on the left side of the radiator shroud is the aux fan relay.
The main fan relay is located on the inside rear of the left wheel well shroud, just below and to the left of the master cylinder.
Old 08-06-2001, 08:46 PM
Togo
Support Corvetteforum!
Togo's Avatar
its amazing how the setups changed over the years....on my 85, the aux fan relay is on the firewall under the master cyilnder, and the main relay is on the "fender well" right behind the driver side front tire. just in case they are not where everybody says, you have other options to look at :D
To aux. fan relay question
Quick Reply: aux. fan relay question
