remote MAT location on SD setup
Old Jan 16, 2006 | 05:58 PM
Trog's Avatar
Trog
Default remote MAT location on SD setup
I'm edging closer to the procharger D1 install in the next few weeks. My shipment from Greg at Blowerworks should arrive w/ inlet tube & his gasous intercooler (alch/water injection) this next week.
Anyway while planning & laying things out I've realized that my remote MAT sensor in my filter housing will no longer be an option. Should I revert to the stock location in the back of the plenum or find a spot in the pressurized intake tract for it?
TIA.
Old Jan 17, 2006 | 03:26 AM
Mo_Bandy's Avatar
Mo_Bandy
If you leave it in the housing make sure it is before the injection nozzle... On the 96 i believe the IAT (Intake ambient Temperature) is the same as a MAT... I have mime just remoted over near the heater / A/C fan housing.... Remote mounting should help with tweaking the fuel as it wont change as the boost goes up and intak temps climb...
That has been my experience any ways....
Hope this helps
Mo
