PCV Valve - LT-1 ????
Jan 20, 2006 | 01:07 AM
Does it have one?
My oil leak has returned and one of the books said it might be caused by a clogged PCV. My service manual does not mention the PCV valve.
If it doesn't have one, is there something else that does the same thing?
Jan 20, 2006 | 01:16 AM
Drivers side of intake , has steel tube running to front under TB
Jan 20, 2006 | 01:25 AM
St. Jude Donor '05-'06
My 93 is on the drivers side and the hose goes to the intake right next to it.
Jan 20, 2006 | 07:10 AM
call greg at blower works. he has a great pcv valve we use on our supercharged engine.
regards
Jan 20, 2006 | 07:35 AM
Cruise-In II Veteran
Feb 14, 2006 | 03:43 PM
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Take care when removing it. It's easy to break the plastic vacuum lines that surround it.
Feb 14, 2006 | 08:09 PM
You did not mention where the leak is at.PCV blockage will increase manifold pressure but most LT1 leaks are caused by the the crappy intake sealing in the front and rear of the intake.If that is where it is you will have to pull it and fix it.
Feb 14, 2006 | 08:17 PM
also the valve cover gaskets may be old
Feb 15, 2006 | 11:07 AM
Quote:
And the rubber grommet the PCV valve is housed in can crack/deterioriate from engine heat, too.
