Racing w/the 4+3
Re: Racing w/the 4+3 (FlyboyZR1)
Well, you really have to slip the clutch a bit while you roll onto the throttle. Practice makes perfect. I usually (street tires) will launch in the 1800 RPM area, then pull the clutch out at a smooth rate while rolling onto the throttle at a slightly higher rate.
