Injectors @ how much PSI
I've got a 96 LT1, with ford performance injectors, and a fuel regulator. I've got a K&N filter with a cut lid, a 160 degree thermostat, a BBK 52mm throttle body, which I bypassed the coolant on, and I've got the Hypertech power programmer. I'm currently running 32 PSI on my injectors and was wondering what others where running and what they thought I should be at.
Re: Injectors @ how much PSI (Shannon1)
I'm running the 24lb F*** injectors at 38/43 lbs (with and without vac.) but I did have to program the injector constant to 25.3 lb. Of couse the chip tuning is always ongoing.........
