ZR1 Wheel Question
Old Mar 7, 2006 | 09:13 AM
silver86's Avatar
silver86
Default ZR1 Wheel Question
Alright....I've checked the archives, and I know this is a very common topic, but I'm still slighlty confused. I found from zr1netregistry.com that the factory offset for the ZR1 rear wheels 36mm. The AFS ZR1 rear wheels have 36.5mm offset for the 84-87 years and 50mm offset for the 88-96 models.
I purchased a set of factory 1990 ZR1 sawblades (hey, everyone has the five stars...I wanted to be different and look a little stock from the side) for my 1986. Since the backspacing is similar on the factory ZR1 rim (36mm) to the AFS specific for my year (36.5mm) will I be able to simply mount the 1990 sawblades I bought on the rear (I know I will need spacers on the front), or is the difference in backspacing enough to force a small spacer on the rear (I don't know the factory backspace on the ZR1 wheels)?
Old Mar 7, 2006 | 10:31 AM
JoBy's Avatar
JoBy
Stock ZR-1 rear offset does fit the 1984-1987 without spacer.
Old Mar 7, 2006 | 10:43 AM
silver86's Avatar
silver86
Out-freakin'-standing!
Now, if I'm doing this right (the math, that is), I need about a 3/4" spacer for the front 17x9.5 wheels right?
Old Mar 7, 2006 | 02:14 PM
AKS Racing's Avatar
AKS Racing
I have the ZR1 wheels on my '87 with no spacers.
Aaron
Old Mar 7, 2006 | 03:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have 90 ZR1's on my 86. Nothing needed in rear and i have a 3/4'' adapter up front.
Looks freakin awsome
Old Mar 7, 2006 | 05:47 PM
corvette1989bham's Avatar
corvette1989bham
Thread jack...so will stock 95 ZR1 17x11 with 36mm offset wheel fit the REAR of a 94 coupe without adapter?
Old Mar 7, 2006 | 06:14 PM
c4cruiser's Avatar
c4cruiser
Yes and no The wheel will bolt on with no problem and clear the calipers and suspension, but the ZR-1 body was wider in the rear to handle the difference in offset and the 11" wide ZR-1-specific rear wheels. The ZR-1 door skins and rear quarter panels were specific to the car so the wheel/tire would fit inside the wheel well opening.
These wheels on your coupe will stick out about 1.5"
The ZR-1 style wheels from the 96 Grand Sport coupe have a different offset and those wheels will work fine on coupes.
Old Mar 8, 2006 | 01:55 AM
JoBy's Avatar
JoBy
No, it will only fit a 1984-1987. The 1988-1996 has a different offset on the wheels and need ZR-1 'style' wheels with 50mm offset. The 36mm offset ZR-1 wheel will be too far out and an adapter will make it worse.
Old Mar 8, 2006 | 05:06 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Ofcourse they will fit, they will just stick out as c4cruiser said. Buy the GrandSport offset or put fender flares on it
Old Mar 8, 2006 | 08:51 AM
JoBy's Avatar
JoBy
Grandsport offset needs the flares ... ZR1 offset will stick out more, too much for me.
To ZR1 Wheel Question
