[Picture Request] People using bullet cats
I'd like to see some pics on how you guys set up your bullet cats on your dual exhaust systems.
tjwong - is that the longtube with extension pipe and cat setup from EM or is it custom? Also what X Pipe is that?
I plan on buying a set of the EM LT's but have not decided if I should go with or without cats. I would also like to run an X pipe and am not sure on the mufflers. Where'd you get the pipes that go from the x pipe to the mufflers?
TIA,
Dave
TIA,
Dave
This looks familiar.....
Originally Posted by sonomacrew01
Mine has the Corsa LT1 system and I had new tubes made from the cats to the resonator out of stainless to match the rest of the system...
Here's mine on putfile. http://putfile.com/pic.php?pic=3/7220132719.jpg&s=x11
It is 3" all the way back from the header collectors. The header collector and cats were slip fit. The installer cut each at an angle with a sawzall and welded on the 3 bolt flange you see. This mounts the cats at an inward angle so they fit this space nearer the engine, and this brings the X-pipe closer to the headers.
